Temp monitor with SMS Alarm
My first version was built 20 years ago and consisted of an analog telephone dialer attached to the mercury switch of an old mechanical thermostat. It played a prerecorded message when the temp dropped below freezing.
Fast forward 20 years and now using a Yun, Blynk and a DS-18 sensor. I can graph history and remotely set the alarm limits so an SMS message is sent when the temp goes below the alarm set level. The code is not anything to be proud of but it works.
Works with Yun and DS-18 Temp Sensor. Set temp for alarm and will email/Txt when below alarm condition at 1 per minute. Alarm can be disabled with switch. Slider sets alarm temp.
Sensor is hooked to Pin 7 with 4.7K pull up resistor.
Uses Blynk , also graphs temp.
#include <Bridge.h>
#include <BlynkSimpleYun.h>
#include <OneWire.h>
//Data wire plugged to digital pin 7 (temp sensor)
#define ONE_WIRE_BUS 7
char auth[] = “xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx”;
WidgetLCD lcd(2); // display info in LCD widget
float temp;
int alarm; // for slider
int button; // for email switch
Blynk.begin(auth);
// Or specify server using one of those commands:
//Blynk.begin(auth, “server.org”, 8442);
//Blynk.begin(auth, server_ip, port);
timer.setInterval(3000, readTemp);
void sendUptime();
BLYNK_WRITE(1){alarm=param.asInt();}
BLYNK_WRITE(V3){button=param.asInt();}
void readTemp()
float floatTempC = sensors.getTempCByIndex(0);
char t_buffer[15];
dtostrf((floatTempC9.0)/5.0+32.0, 8, 9, t_buffer);
Blynk.virtualWrite(5, t_buffer);
float alarmF = (alarm
9.0)/5.0+32.0;
lcd.clear(); //Use it to clear the LCD Widget
lcd.print(4, 0, alarmF); // use: (position X: 0-15, position Y: 0-1, “Message you want to print”)
lcd.print(4, 1, “Alarm F”);
// send email if temp is below and email button activated.
if ((floatTempC < alarm) && (button == 1))
Blynk.email("5551234567@vtext.com", “Temp Alert”, “Temp below Alarm”);
Blynk.run();// Initiates Blynk
Please edit your post. Code should be formatted.
Wrap the code by pressing this magic button (Backtick`) 3 times (before the code and after it):**
Example:
 ``` <--- insert this
 Paste your code here
This makes your code beautiful with highlighted syntax, like this:
//comment goes here
void helloWorld() {
   String message =  "hello" + "world";
You can also select the code and press </> button in the top menu:
Thanks for sharing your project! Like the history part! :slight_smile:
One More time but prettier code :slight_smile:
 *   Downloads, docs, tutorials: http://www.blynk.cc
 *   Blynk community:            http://community.blynk.cc
 *   Social networks:            http://www.fb.com/blynkapp
 *                               http://twitter.com/blynk_app
Works with Yun abd DS-18 Temp Sensor.  Set temp for alarm and will email/Txt when below alarm condition at 1 per minute.
#include <Bridge.h>
char auth[] = "3b040945785244bea81746efe4d5c788";
float temp;
  Blynk.begin(auth);
  //Blynk.begin(auth, "server.org", 8442);
    void sendUptime();
void readTemp()
  char t_buffer[15];
  dtostrf((floatTempC*9.0)/5.0+32.0, 8, 9, t_buffer);
  float alarmF = (alarm*9.0)/5.0+32.0;
  lcd.print(4, 0, alarmF); // use: (position X: 0-15, position Y: 0-1, "Message you want to print")
  lcd.print(4, 1, "Alarm F");
  // send email temp is below and email button activated.
Blynk.email("5551234567@vtext.com", "Temp Alert", "Temp below Alarm");
