Telepresence robot with skype live stream?
So im trying to make a telepresence robot like ive seen on you tube. Ive copied code that wouldn’t compile and tweaked it to do atleast that but im stuck on the part were i connect a skype video stream from the android phone on the robot to the live video widget on the app. Would greatly appreciate any help i can get as this is my first attempt at connecting anything to wifi let alone video streams. Im making a tracked robot with a wemos mini D1 connected to a l298n. The app uses a joystick to control it but i cant figure out what pins i should connect the joystick to in the app (virtual/digital???) New to this app and hope im posting this right because it isn’t the most intuitive. This code as i said was codied and reworked to compile but im not sure.
// Setup L298N Motor Controller Input Pins
int IN1 = D6;  // Motor 2
int IN2 = D5;  // Motor 2
int IN3 = D2;  // Motor 1
int IN4 = D1;  // Motor 1
int ENA = D7;
int ENB = D8;
int Flag = 1;
char incomingByte;
char auth[] = "vwARajksHH1xoQdpHyloPjQAC5uMkzK7";
char ssid[] = "MySpectrumWiFi0a-2G";
char pass[] = "***************";
  // setup L298N Motor Controller Input Pins
  pinMode(IN1, OUTPUT);
  pinMode(IN2, OUTPUT);
  pinMode(IN3, OUTPUT);
  pinMode(IN4, OUTPUT);
  pinMode(ENA, OUTPUT);
  pinMode(ENB, OUTPUT);
  analogWrite(ENA, 150);
  analogWrite(ENB, 150);
BLYNK_WRITE(V6)  // Joystick Widget Input
  Flag = 1;
  int y = param[1].asInt();
  int x = param[0].asInt();
  if (y > 750 && Flag == 1) {  // Forward
    Flag = 0;
    incomingByte = '1';
    ControlOutput();
  if (y < 250 && Flag == 1) {  // Backward
    Flag = 0;
    incomingByte = '2';
    ControlOutput();
  if (x < 250 && Flag == 1) {  // Left
    Flag = 0;
    incomingByte = '3';
    ControlOutput();
  if (x > 750 && Flag == 1) {  // Right
    Flag = 0;
    incomingByte = '4';
    ControlOutput();
  if (y == 512 && y == 512) {  // Full Stop
    incomingByte = '0';
    ControlOutput();
BLYNK_WRITE(V0)
  digitalWrite(IN1, pinValue);
  digitalWrite(IN2, pinValue);
  digitalWrite(IN3, pinValue);
  digitalWrite(IN4, pinValue);
//  Take inputs and direct motor control functions
void ControlOutput() {
  switch (incomingByte) {
    case '1': {
        motor1Forward();
        motor2Forward();
        Blynk.virtualWrite(V1, "Forward");
      break;
    case '2': {
        motor1Backwards();
        motor2Backwards();
        Blynk.virtualWrite(V1, "Backward");
      break;
    case '3': {
        motor1Backwards();
        motor2Forward();
        Blynk.virtualWrite(V1, "Spin Left");
      break;
    case '4': {
        motor1Forward();
        motor2Backwards();
        Blynk.virtualWrite(V1, "Spin Right");
      break;
    default: {
        Blynk.virtualWrite(V1, "Full Stop");
        motor1Stop();
        motor2Stop();
        Flag = 1;
      break;
// Functions to control L298N Motor Controller Input Pins
void motor1Forward() {
  digitalWrite(IN4, HIGH);
  digitalWrite(IN3, LOW);
void motor1Backwards() {
  digitalWrite(IN4, LOW);
  digitalWrite(IN3, HIGH);
void motor1Stop() {
void motor2Forward() {
  digitalWrite(IN2, HIGH);
  digitalWrite(IN1, LOW);
void motor2Backwards() {
  digitalWrite(IN2, LOW);
  digitalWrite(IN1, HIGH);
void motor2Stop() {
