Telegram crashes
Hello all,
I have a problem with the following code below.
Every time Blynk sends a telegram, it will be rebooted. If the Telegram line (bot.sendMessage(“XXXX”, String(counter)):wink: is commented, the serial monitor is nicely showing the detection.
I am using a Wemos D1 mini lite
What am I doing wrong?
    Follow us:                  http://www.fb.com/blynkapp
                                http://twitter.com/blynk_app
  You’ll need:
   - Blynk App (download from AppStore or Google Play)
   - ESP8266 board
  started. Think of them as LEGO bricks  and combine them as you wish.
  example.
#include <BlynkSimpleEsp8266_SSL.h>
#include <WiFiClientSecure.h>
#include <TelegramBot.h>
// Initialize Telegram BOT
const char BotToken[] = "XXXX";
WiFiClientSecure net_ssl;
TelegramBot bot (BotToken, net_ssl);
char auth[] = "XXXX";
int counter = 0;
int buzzer = 0;
int doorbell=0;
int doorbell_detect=0;
void myTimerEvent()
  doorbell = doorbell + 1;
  if (buzzer=1){
  counter = counter + 1;
  Serial.println(counter);
    if (counter >=5){
      digitalWrite(D5, LOW);
char ssid[] = "XXXX";
char pass[] = "XXXX";
BLYNK_WRITE(V0) {
  if (param.asInt()) {
    digitalWrite(D5, HIGH);
    counter = 0;
    Serial.print("counter reset");
    buzzer = 1;
   // Setup notification button on pin D6
  pinMode(D6, INPUT);
  doorbell_detect=0;
  // Attach pin D6 interrupt to our handler
  attachInterrupt(digitalPinToInterrupt(D6), notifyOnButtonPress, CHANGE);
void notifyOnButtonPress()
  // Invert state, since button is "Active LOW"
  int isButtonPressed = !digitalRead(D6);
  //Serial.println(isButtonPressed);
  if (isButtonPressed) {
    if (doorbell >= 15){
      doorbell = 0;
      doorbell_detect=1;
      Serial.println("Doorbell detected");
      bot.sendMessage("XXXX", String(counter));
  // to avoid delay() function!
    notifyOnButtonPress();
Perhaps you should be running this function call in a timer as well? Instead of in the void loop() where if you press the button this function is called hundreds/thousands of times a second = disconnection :wink:
than I get this:
Exception (29):
epc1=0x4020e36e epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000004 depc=0x00000000
ctx: cont
sp: 3fff0b90 end: 3fff1520 offset: 01a0
>>>stack>>>
3fff0d30:  00820000 00000082 3fff8444 4021b646
3fff0d40:  3fff0414 3fff86c4 3fff8444 4021b840
3fff0d50:  3fffbafc 00000208 3fffbafc 40100670
3fff0d60:  00000104 0000a0b8 00001417 00000042
3fff0d70:  00000040 00000082 3fffa224 4021bb59
3fff0d80:  00800000 00000080 00000000 00000041
3fff0d90:  00000040 0000003f 3fff5ddc 00000041
3fff0da0:  3fffb6e4 3fffa224 3fff5ddc 3fff8bc4
3fff0db0:  3fffbbf8 ffffffff 3fff86c4 402068b0
3fff0dc0:  00000040 3fff86c4 3fffa224 3fff86c4
3fff0dd0:  00000040 3fff86c4 3fffa224 4021c693
3fff0de0:  3fff8764 0000003f 3c68f607 00000001
3fff0df0:  3fff86c4 3fffa20c 3fffa224 00000001
3fff0e00:  00000010 3fff86c4 0000000f 4021c8e8
3fff0e10:  3fff5ddc 3fff89a4 0000000f 00000001
3fff0e20:  00000001 3fff5dc4 3fff65ca 4021b6ec
3fff0e30:  00000100 3fff8734 3fff6587 00000000
3fff0e40:  00000100 3fff8734 3fff6587 4021db01
3fff0e50:  3fff0e80 00000000 000000d0 00000030
3fff0e60:  df1f12d5 3fff5de8 3fff5dd0 00000004
3fff0e70:  3fff6581 3fff5e4c 3fff6581 4021876c
3fff0e80:  c3020303 9688e93d d004223e cc01b9e6
3fff0e90:  58801972 ff0aedcb a852e5ab d2f218d1
3fff0ea0:  6970312f 7c69bd3e 7af817c4 12d5d654
3fff0eb0:  3fff6581 00000004 3fff5e4c 40218c01
3fff0ec0:  ed7fa74a 2c09e9c7 ad799967 402159ac
3fff0ed0:  fa6b2c23 3fffc6fc 3fff0500 40211509
3fff0ee0:  00000000 00000004 00000004 40204537
3fff0ef0:  00000006 00001246 00000064 40206870
3fff0f00:  0000004a 00000000 00000026 00000004
3fff0f10:  3fff6581 00000004 3fff5e4c 00000004
3fff0f20:  3fff6581 00000004 3fff5e4c 40218574
3fff0f30:  0eb2b1b0 00000000 00000000 00000027
3fff0f40:  0000005c 3fff6581 3fff5e4c 40218950
3fff0f50:  00000010 3fff65b4 3fff5e4c 401004d8
3fff0f60:  3fff0fb0 0000000e 00000010 00000000
3fff0f70:  00000000 3fff24ec 3fff5e4c 01000000
3fff0f80:  3fff0fb0 3fff295c 3fff5e4c 402186dc
3fff0f90:  3fff0104 3fff295c 3fff0104 3fff5aac
3fff0fa0:  00008a35 3fff295c 3fff0104 40204d3c
3fff0fb0:  3fff0104 00000000 3fff5a74 40203f42
3fff0fc0:  3fff5a74 00003a98 3fff1458 3fff00f8
3fff0fd0:  000001bb 3fff0104 3ffe939a 3fff00f8
3fff0fe0:  000001bb 3fff0104 3ffe939a 40204ea1
3fff0ff0:  3ffe9618 dca79a95 3ffe9618 dca79a95
3fff1000:  3fff14b0 3fff1458 3fff00f8 40205348
3fff1010:  3fff2924 00000023 3fff00f8 402053f8
3fff1020:  0000007d 00000000 3fff1458 4020630d
3fff1030:  3fff1070 3fff14b0 3fff1458 402063cc
3fff1040:  3fff1070 3fff1094 3fff1464 3fff00f8
3fff1050:  3fff1070 3fff14b0 3fff1464 40205c47
3fff1060:  3ffe9538 3fff1070 000003e8 00000037
3fff1070:  3fff1060 3fff1078 3fff1094 3ffe94b6
3fff1080:  00000002 3fff1088 37373834 38303839
3fff1090:  ffff0039 00000000 3ffe948c 00000002
3fff10a0:  3fff10a4 3f003132 3fff1b1c 00000001
3fff10b0:  40233d3e 3ffedb98 3fff1b1c 3ffedb98
3fff10c0:  00000002 00000000 00000020 40100ec6
3fff10d0:  3ffea402 40232d07 3ffedb98 3fff2a8a
3fff10e0:  00000000 40226397 3ffef018 a4247ff5
3fff10f0:  00000000 00000002 00000000 3ffedb98
3fff1100:  3fff2a8a 40104456 3fff1edc 3fff28cc
3fff1110:  ec7e1d7e cd289c6a dd16feea aca8d66b
3fff1120:  22265c9d 80000000 00000000 00000000
3fff1130:  00000000 00000000 00000000 00000000
3fff1140:  00000000 00000000 40233be3 00000000
3fff1150:  ffffffff 00000000 3ffea551 00000000
3fff1160:  c3bc5b83 18e106ed abf0289b 6cfed4b9
3fff1170:  73b9f885 80000000 00000000 00000000
3fff1180:  00000000 00000000 00000000 00000000
3fff1190:  00000000 00000000 00000000 000002a0
3fff11a0:  d098e630 e83fa4a8 b093a57d 78cc6512
3fff11b0:  370cb85b 61274afa f198ca24 6e1975f6
3fff11c0:  637f5995 334edd18 bd15a117 3766790e
3fff11d0:  0884ca86 b865d29b 2cccaa34 1d4432f1
3fff11e0:  76239087 1ee36d2d 4f9d1d80 b15d8cc2
3fff11f0:  a1e7aba9 f18de02f 1eed6a8e c3e8636d
3fff1200:  b3891054 084d476a 73c82af8 1bae6e07
3fff1210:  1bc518e3 4ec8557a bf587c74 b71448a5
3fff1220:  89ff9053 3157b5e2 554da8e8 a5032573
3fff1230:  00000005 00000000 00000020 40100ec6
3fff1240:  3ffea405 401042c3 3ffede40 89336161
3fff1250:  40101be1 3ffede40 a3d595fb 0a6103fa
3fff1260:  00007fff 02188022 3ffee8c8 40101db2
3fff1270:  3ffeaca4 00000000 00000000 adb00ac4
3fff1280:  00007fff 02188022 401021f2 00000100
3fff1290:  7fffffff 3ffeaca4 3ffeaca4 00000001
3fff12a0:  00000001 00000080 00000000 1a1b0783
3fff12b0:  00007fff 02188022 00000000 4000050c
3fff12c0:  3fffc278 40101f8c 3fffc200 00000022
3fff12d0:  3ffeacb0 00000080 00000005 00000000
3fff12e0:  402044c1 00000030 00000014 ffffffff
3fff12f0:  40204995 3fff316c 3fff3cf1 00000005
3fff1300:  00000005 00000000 00000020 40100ec6
3fff1310:  3ffea405 401042c3 3ffede40 00000005
3fff1320:  40101be1 3ffede40 01860017 00000030
3fff1330:  00007fff 021a1023 3ffee8c8 40101db2
3fff1340:  3ffeacb0 00000000 00000000 00000005
3fff1350:  00007fff 021a1023 401021f2 00000100
3fff1360:  7fffffff 3ffeacb0 3ffeacb0 00000001
3fff1370:  00000001 00000080 0000001f 40104ee9
3fff1380:  4000050c 021a1023 00000000 4000050c
3fff1390:  3fffc278 40101f8c 3fffc200 00000022
3fff13a0:  3ffeacbc 00000023 00000001 00000001
3fff13b0:  4000e235 00000030 00000010 ffffffff
3fff13c0:  00000000 00000000 0000001f 40104ee9
3fff13d0:  00000000 00000000 0000001f 3fff0414
3fff13e0:  00000010 00000010 00000000 4010053d
3fff13f0:  33323130 37363534 62613938 66656463
3fff1400:  6a696867 6e6d6c6b 7271706f 3fff04f4
3fff1410:  00000010 3fff14c8 3fff14c8 4020628f
3fff1420:  3fff1470 00000002 3fff14c8 402062db
3fff1430:  3ffefeac 00000009 3fff14c8 4020630d
3fff1440:  3ffefc60 3fff0434 3fff14c8 40206439
3fff1450:  3fff1470 3fff14bc 3fff5a3c 0000002f
3fff1460:  00000023 3fff2924 0000002f 00000023
3fff1470:  3fff1464 3fff0434 3fff14bc 4020630d
3fff1480:  3fff14c8 00000000 3fff14bc 4020635a
3fff1490:  3ffe8a4f 3fff0144 3fff0434 3fff04f4
3fff14a0:  3ffefc60 3fff0434 3fff00f4 4020256d
3fff14b0:  00000000 3fff0144 3fff0120 3fff6154
3fff14c0:  0000000f 00000009 3fff290c 0000000f
3fff14d0:  00000002 3fff0434 3fff04ec 40204f48
3fff14e0:  00000000 3ffefeac 3ffefeac 4020511c
3fff14f0:  3fffdad0 00000000 3fff04ec 4020355c
3fff1500:  3fffdad0 00000000 3fff04ec 40206844
3fff1510:  feefeffe feefeffe 3fff0500 40100710
This is bad code, you should be using == not =
Probably bad use of attachInterrupt()
I don’t think so, if I want to send the telegram message via the pushbutton buzzer, it ends up in reboots as well
Push button buzzer works fine without telegram
if (buzzer==1){
    if (counter >=5){
      bot.sendMessage("XXX", String(counter));
