Hi.
I’m using a library by Giancarlo Bacchio https://github.com/Gianbacchio/ESP8266-TelegramBot to get and send messages via Telegram with esp8266.
Working nice, but it has bottoken, botname and botusername in the code.
I decided to read it from eeprom. But arduino ide want me to declare bottoken, botname and botusername or declare class bot before starting reading eeprom. Can you help me with this code?
#include <WiFiClientSecure.h>
#include <ESP8266TelegramBOT.h>
#include <EEPROM.h>
// Initialize Wifi connection to the router
char ssid[] = "xxxxxxxxxxxxxxxxxxxxxx"; // your network SSID (name)
char pass[] = "yyyyyyyy"; // your network key
typedef struct {
String BOTtoken_eeprom;
String BOTname_eeprom;
String BOTusername_eeprom;
} WMSettings;
WMSettings EEPROMsettings;
int Bot_mtbs = 1000; //mean time between scan messages
long Bot_lasttime; //last time messages' scan has been done
bool Start = false;
EchoMessages - function to Echo messages
void Bot_ExecMessages() {
for (int i = 1; i < bot.message[0][0].toInt() + 1; i++) {
bot.message[i][5] = bot.message[i][5].substring(1, bot.message[i][5].length());
if (bot.message[i][5] == "\/ledon") {
digitalWrite(13, HIGH); // turn the LED on (HIGH is the voltage level)
bot.sendMessage(bot.message[i][4], "Led is ON", "");
if (bot.message[i][5] == "\/ledoff") {
digitalWrite(13, LOW); // turn the LED off (LOW is the voltage level)
bot.sendMessage(bot.message[i][4], "Led is OFF", "");
if (bot.message[i][5] == "\/start") {
String wellcome = "Wellcome from FlashLedBot, your personal Bot on ESP8266 board";
String wellcome1 = "/ledon : to switch the Led ON";
String wellcome2 = "/ledoff : to switch the Led OFF";
bot.sendMessage(bot.message[i][4], wellcome, "");
bot.sendMessage(bot.message[i][4], wellcome1, "");
bot.sendMessage(bot.message[i][4], wellcome2, "");
Start = true;
bot.message[0][0] = ""; // All messages have been replied - reset new messages
delay(3000);
// attempt to connect to Wifi network:
Serial.print("Connecting Wifi: ");
Serial.println(ssid);
while (WiFi.begin(ssid, pass) != WL_CONNECTED) {
Serial.print(".");
delay(500);
// read setting from eeprom
EEPROM.begin(512);
EEPROM.get(0, EEPROMsettings);
EEPROM.end();
// Initialize Telegram BOT
TelegramBOT bot(EEPROMsettings.BOTtoken_eeprom, EEPROMsettings.BOTname_eeprom, EEPROMsettings.BOTusername_eeprom);
bot.begin(); // launch Bot functionalities
pinMode(2, OUTPUT); // initialize digital pin 2 as an output.
if (millis() > Bot_lasttime + Bot_mtbs) {
bot.getUpdates(bot.message[0][1]); // launch API GetUpdates up to xxx message
Bot_ExecMessages(); // reply to message with Echo
Bot_lasttime = millis();
