Hi i am having problem with connecting teensy 4.0 and esp8266 01 to the blynk app. I am using blynk.ncp example to connect esp with blynk, but connection last just a minute or two and then disconnect. Did somebody try to connect esp 01 with boards that are not presets? Can somebody help me…
More information required.
This is code:
#define BLYNK_TEMPLATE_ID "TMPL4HCqFA46y"
#define BLYNK_TEMPLATE_NAME "ON OFF"
// Define NCP connection port settings, if needed
#define BLYNK_NCP_SERIAL Serial1
#define BLYNK_NCP_BAUD 115200
#define SerialDbg Serial
#include "ArduinoUtils.h"
SerialDbg.begin(115200);
waitSerialConsole(SerialDbg);
// Power-up NCP (if needed)
#if defined(ARDUINO_NANO_RP2040_CONNECT)
pinMode(NINA_RESETN, OUTPUT);
digitalWrite(NINA_RESETN, HIGH);
#endif
if (!ncpSetupSerial()) {
return;
const char* ncpFwVer = "unknown";
if (rpc_blynk_getNcpVersion(&ncpFwVer)) {
SerialDbg.print(F("NCP firmware: "));
SerialDbg.println(ncpFwVer);
// Setup the indicator LED, user button (if needed)
rpc_hw_initRGB(27, 25, 26, true);
rpc_hw_setLedBrightness(128);
#elif defined(BLYNK_NCP_TYPE_WITTY_CLOUD)
rpc_hw_initUserButton(4, true);
rpc_hw_initRGB(15, 12, 13, false);
#else
//rpc_hw_initUserButton(0, true);
//rpc_hw_initLED(19, false);
//rpc_hw_setLedBrightness(160);
#endif
// Set config mode timeout to 30 minutes, for testing purposes
rpc_blynk_setConfigTimeout(30*60);
// Provide MCU firmware info to the NCP
// This info is mainly used for the Primary MCU OTA updates
rpc_blynk_setFirmwareInfo(BLYNK_FIRMWARE_TYPE,
BLYNK_FIRMWARE_VERSION,
BLYNK_FIRMWARE_BUILD_TIME,
BLYNK_RPC_LIB_VERSION);
// White labeling (use this ONLY if you have a branded Blynk App)
//rpc_blynk_setVendorPrefix("MyCompany");
//rpc_blynk_setVendorServer("dashboard.mycompany.com");
// Product setup
if (!rpc_blynk_initialize(BLYNK_TEMPLATE_ID, BLYNK_TEMPLATE_NAME)) {
SerialDbg.println(F("rpc_blynk_initialize failed"));
void sendPeriodicMessage()
static uint32_t last_change = millis();
if (millis() - last_change > 10000) {
last_change += 10000;
// Send a value to Blynk Virtual Pin 1
virtualWrite(1, millis());
rpc_run();
sendPeriodicMessage();
// Handle Blynk Virtual Pin value updates
void rpc_client_blynkVPinChange_impl(uint16_t vpin, buffer_t param)
// NOTE: we could copy the buffer, but we use 0-copy instead
// But we need to 0-terminate it, overwriting the CRC8
param.data[param.length] = '\0';
SerialDbg.print(F("Got data on Virtual Pin "));
SerialDbg.println(vpin);
// Param format. Most values will be plain strings: "Hello world", "1234", "123.456", etc.
// However, sometimes the value contains multiple items (an array). In this case, the values are separated using a 0x00 byte, i.e:
// "First\0Second\0Third"
// Define the callback for the NCP state change event
void rpc_client_blynkStateChange_impl(uint8_t state)
SerialDbg.print(F("NCP state: "));
SerialDbg.println(ncpGetStateString(state));
if ((RpcBlynkState)state == BLYNK_STATE_CONNECTED) {
// Send a value to Virtual Pin 1
virtualWrite(1, "hello world!");
// Handle various NCP events
void rpc_client_processEvent_impl(uint8_t event)
switch ((RpcEvent)event) {
* System events
case RPC_EVENT_NCP_REBOOTING:
SerialDbg.println(F("NCP is rebooting. TODO: reinitialize NCP"));
break;
case RPC_EVENT_BLYNK_PROVISIONED:
SerialDbg.println(F("NCP finished provisioning"));
break;
case RPC_EVENT_BLYNK_TIME_SYNC:
SerialDbg.println(F("NCP requests time sync from external time source"));
break;
case RPC_EVENT_BLYNK_TIME_CHANGED: break;
SerialDbg.println(F("NCP local time changed"));
break;
* User button events (see rpc_hw_initUserButton)
case RPC_EVENT_HW_USER_CLICK:
SerialDbg.println(F("NCP: user button click"));
break;
case RPC_EVENT_HW_USER_DBLCLICK:
SerialDbg.println(F("NCP: user button double click"));
break;
case RPC_EVENT_HW_USER_LONGPRESS:
SerialDbg.println(F("NCP: user button long press start"));
break;
case RPC_EVENT_HW_USER_LONGRELEASE:
SerialDbg.println(F("NCP: user button long press stop"));
break;
case RPC_EVENT_HW_USER_RESET_START:
SerialDbg.println(F("NCP: Button is pressed for 10 seconds => release to clear configuration"));
break;
case RPC_EVENT_HW_USER_RESET_CANCEL:
SerialDbg.println(F("NCP: Button is pressed for 15 seconds => cancel config reset operation"));
break;
case RPC_EVENT_HW_USER_RESET_DONE:
SerialDbg.println(F("NCP: Button was released => configuration is reset"));
break;
default: break;
and this is what serial monitor gives me:
Blynk.NCP ready, baud: 230400
NCP firmware: 0.6.3
NCP state: Configuration
@Zac7 Please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code and serial output so that they display correctly.
I did it
