BLYNK
BLYNK.IO       📲 GETTING STARTED       📗 DOCS       ❓HELP CENTER       👉 SKETCH BUILDER
Tab Widget suggestions
It would be wonderful to be able to reorder your tabs. If you get a lot of widgets lined up just like you want them on a tab, and then have to add a tab before it, you have to more everything to the previous tab.
Also, even more importantly, if a tab widget had a virtual pin connected to it. So when the user clicks a certain tab in the tabs, you could have the hardware push updates to the widgets on that tab.
This is not possible now, correct?
This was already replied. Please search before posting.
Thanks!
I did search. I found people wanting to do it but found answers that said it can’t be done. That’s why I added another voice and put it in the category app feature suggestion.
Because it’s a suggestion.
Sorry if I did it wrong.
Reordering of tabs is already planned feature
