Why button don’t work
On the phone is fine but physical button not working
someone have a idea why
help
#include <ESP8266_Lib.h>
char auth[] = "xxx";
char ssid[] = "xxx";
char pass[] = "xxx";
#define EspSerial Serial1
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
const int led1Pin = 48;
const int btn1Pin = 8;
const int led2Pin = 49;
const int btn2Pin = 8;
const int led3Pin = 50;
const int btn3Pin = 8;
const int led4Pin = 47;
const int btn4Pin = 8;
const int led5Pin = 45;
const int btn5Pin = 8;
const int led6Pin = 44;
const int btn6Pin = 8;
const int led7Pin = 46;
const int btn7Pin = 8;
const int led8Pin = 38;
const int btn8Pin = 39;
const int led9Pin = 36;
const int btn9Pin = 40;
const int led10Pin = 37;
const int btn10Pin = 41;
const int led11Pin = 35;
const int btn11Pin = 42;
const int led12Pin = 43;
const int btn12Pin = 31;
const int btn13Pin = 33;
const int btn14Pin = 32;
const int btn15Pin = 53;
const int btn16Pin = 30;
WidgetLED led13(V13);
WidgetLED led14(V14);
WidgetLED led15(V15);
WidgetLED led16(V16);
void checkPhysicalButton1();
void checkPhysicalButton2();
void checkPhysicalButton3();
void checkPhysicalButton4();
void checkPhysicalButton5();
void checkPhysicalButton6();
void checkPhysicalButton7();
void checkPhysicalButton8();
void checkPhysicalButton9();
void checkPhysicalButton10();
void checkPhysicalButton11();
void checkPhysicalButton12();
int led1State = LOW;
int btn1State = HIGH;
int led2State = LOW;
int btn2State = HIGH;
int led3State = LOW;
int btn3State = HIGH;
int led4State = LOW;
int btn4State = HIGH;
int led5State = LOW;
int btn5State = HIGH;
int led6State = LOW;
int btn6State = HIGH;
int led7State = LOW;
int btn7State = HIGH;
int led8State = LOW;
int btn8State = HIGH;
int led9State = LOW;
int btn9State = HIGH;
int led10State = LOW;
int btn10State = HIGH;
int led11State = LOW;
int btn11State = HIGH;
int led12State = LOW;
int btn12State = HIGH;
{ Serial.begin(9600);
pinMode(led1Pin, OUTPUT);
pinMode(btn1Pin, INPUT_PULLUP);
digitalWrite(led1Pin, led1State);
pinMode(led2Pin, OUTPUT);
pinMode(btn2Pin, INPUT_PULLUP);
digitalWrite(led2Pin, led2State);
pinMode(led3Pin, OUTPUT);
pinMode(btn3Pin, INPUT_PULLUP);
digitalWrite(led3Pin, led3State);
pinMode(led4Pin, OUTPUT);
pinMode(btn4Pin, INPUT_PULLUP);
digitalWrite(led4Pin, led4State);
pinMode(led5Pin, OUTPUT);
pinMode(btn5Pin, INPUT_PULLUP);
digitalWrite(led5Pin, led5State);
pinMode(led6Pin, OUTPUT);
pinMode(btn6Pin, INPUT_PULLUP);
digitalWrite(led6Pin, led6State);
pinMode(led7Pin, OUTPUT);
pinMode(btn7Pin, INPUT_PULLUP);
digitalWrite(led7Pin, led7State);
pinMode(led8Pin, OUTPUT);
pinMode(btn8Pin, INPUT_PULLUP);
digitalWrite(led8Pin, led8State);
pinMode(led9Pin, OUTPUT);
pinMode(btn9Pin, INPUT_PULLUP);
digitalWrite(led9Pin, led9State);
pinMode(led10Pin, OUTPUT);
pinMode(btn10Pin, INPUT_PULLUP);
digitalWrite(led10Pin, led10State);
pinMode(led11Pin, OUTPUT);
pinMode(btn11Pin, INPUT_PULLUP);
digitalWrite(led11Pin, led11State);
pinMode(led12Pin, OUTPUT);
pinMode(btn12Pin, INPUT_PULLUP);
digitalWrite(led12Pin, led12State);
pinMode(btn13Pin, INPUT_PULLUP);
pinMode(btn14Pin, INPUT_PULLUP);
pinMode(btn15Pin, INPUT_PULLUP);
pinMode(btn16Pin, INPUT_PULLUP);
timer.setInterval(100L, checkPhysicalButton1);
timer.setInterval(100L, checkPhysicalButton2);
timer.setInterval(100L, checkPhysicalButton3);
timer.setInterval(100L, checkPhysicalButton4);
timer.setInterval(100L, checkPhysicalButton5);
timer.setInterval(100L, checkPhysicalButton6);
timer.setInterval(100L, checkPhysicalButton7);
timer.setInterval(100L, checkPhysicalButton8);
timer.setInterval(100L, checkPhysicalButton9);
timer.setInterval(100L, checkPhysicalButton10);
timer.setInterval(100L, checkPhysicalButton11);
timer.setInterval(100L, checkPhysicalButton12);
timer.setInterval(500L, buttonLedWidget13);
timer.setInterval(500L, buttonLedWidget14);
timer.setInterval(500L, buttonLedWidget15);
timer.setInterval(500L, buttonLedWidget16);
BLYNK_CONNECTED() {
Blynk.syncVirtual(V1);
Blynk.syncVirtual(V2);
Blynk.syncVirtual(V3);
Blynk.syncVirtual(V4);
Blynk.syncVirtual(V5);
Blynk.syncVirtual(V6);
Blynk.syncVirtual(V7);
Blynk.syncVirtual(V8);
Blynk.syncVirtual(V9);
Blynk.syncVirtual(V10);
Blynk.syncVirtual(V11);
Blynk.syncVirtual(V12);
BLYNK_WRITE(V1) {
led1State = param.asInt();
if (digitalRead(btn1Pin) == LOW) {
if (btn1State != LOW) {
led1State = !led1State;
Blynk.virtualWrite(V1, led1State);
btn1State = LOW;
btn1State = HIGH;
BLYNK_WRITE(V2) {
led2State = param.asInt();
if (digitalRead(btn2Pin) == LOW) {
if (btn2State != LOW) {
led2State = !led2State;
Blynk.virtualWrite(V2, led2State);
btn2State = LOW;
btn2State = HIGH;
BLYNK_WRITE(V3) {
led3State = param.asInt();
if (digitalRead(btn3Pin) == LOW) {
if (btn3State != LOW) {
led3State = !led3State;
Blynk.virtualWrite(V3, led3State);
btn3State = LOW;
btn3State = HIGH;
BLYNK_WRITE(V4) {
led4State = param.asInt();
if (digitalRead(btn4Pin) == LOW) {
if (btn4State != LOW) {
led4State = !led4State;
Blynk.virtualWrite(V4, led4State);
btn4State = LOW;
btn4State = HIGH;
BLYNK_WRITE(V5) {
led5State = param.asInt();
if (digitalRead(btn5Pin) == LOW) {
if (btn5State != LOW) {
led5State = !led5State;
Blynk.virtualWrite(V5, led5State);
btn5State = LOW;
btn5State = HIGH;
BLYNK_WRITE(V6) {
led6State = param.asInt();
if (digitalRead(btn6Pin) == LOW) {
if (btn6State != LOW) {
led6State = !led6State;
Blynk.virtualWrite(V6, led6State);
btn6State = LOW;
btn6State = HIGH;
BLYNK_WRITE(V7) {
led7State = param.asInt();
if (digitalRead(btn7Pin) == LOW) {
if (btn7State != LOW) {
led7State = !led7State;
Blynk.virtualWrite(V7, led7State);
btn7State = LOW;
btn7State = HIGH;
BLYNK_WRITE(V8) {
led8State = param.asInt();
if (digitalRead(btn8Pin) == LOW) {
if (btn8State != LOW) {
led8State = !led8State;
Blynk.virtualWrite(V8, led8State);
btn8State = LOW;
btn8State = HIGH;
BLYNK_WRITE(V9) {
led9State = param.asInt();
if (digitalRead(btn9Pin) == LOW) {
if (btn9State != LOW) {
led9State = !led9State;
Blynk.virtualWrite(V9, led9State);
btn9State = LOW;
btn9State = HIGH;
BLYNK_WRITE(V10) {
led10State = param.asInt();
if (digitalRead(btn10Pin) == LOW) {
if (btn10State != LOW) {
led10State = !led10State;
Blynk.virtualWrite(V10, led10State);
btn10State = LOW;
btn10State = HIGH;
BLYNK_WRITE(V11) {
led11State = param.asInt();
if (digitalRead(btn11Pin) == LOW) {
if (btn11State != LOW) {
led11State = !led11State;
Blynk.virtualWrite(V11, led11State);
btn11State = LOW;
btn11State = HIGH;
BLYNK_WRITE(V12) {
led12State = param.asInt();
if (digitalRead(btn12Pin) == LOW) {
if (btn12State != LOW) {
led12State = !led12State;
Blynk.virtualWrite(V12, led12State);
btn12State = LOW;
btn12State = HIGH;
boolean btn13State = false;
void buttonLedWidget13()
{ boolean isPressed = (digitalRead(btn13Pin) == LOW);
if (isPressed != btn13State) {
if (isPressed) {
led13.on();
led13.off();
btn13State = isPressed;
boolean btn14State = false;
void buttonLedWidget14()
{ boolean isPressed = (digitalRead(btn14Pin) == LOW);
if (isPressed != btn14State) {
if (isPressed) {
led14.on();
led14.off();
btn14State = isPressed;
boolean btn15State = false;
void buttonLedWidget15()
{ boolean isPressed = (digitalRead(btn15Pin) == LOW);
if (isPressed != btn15State) {
if (isPressed) {
led15.on();
led15.off();
btn15State = isPressed;
boolean btn16State = false;
void buttonLedWidget16()
{ boolean isPressed = (digitalRead(btn16Pin) == LOW);
if (isPressed != btn16State) {
if (isPressed) {
led16.on();
led16.off();
btn16State = isPressed;
