I’m trying to use the syncall() function, and according to my reading and the examples, it should call functions for the virtual pins, but my code does not restore the previous values after a reboot, instead it populates the Vpins with current values.
Specifically, I keep a running value that tracks the maximum and minimum temperatures in my roof which are stored in V35 and V36. SyncAll() is called in the setup(), and I thought it would call the BlynkWrite(V35) and (36) and restore the original values to the variable registers.
This is not happening, so I would appreciate any comments on my code. (I have deleted all the OTA code and other functions not relevant to this question, in order to simplify what I’m presenting).
This runs directly on ESP32 chip.
22 June 2018: Created initial app for ESP32
* Libraries
#include <OneWire.h>
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#include <ESPmDNS.h>
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
* DS18B20 Sensor setup
#define ONE_WIRE_BUS 4
DallasTemperature sensors(&oneWire); // Pass our oneWire reference to Dallas Temperature.
DeviceAddress officeThermometer, roofThermometer; // arrays to hold device address
* BLYNK Setup
char auth[] = "xxxx";
char ssid[] = "xxxx";
char pass[] = "xxxx";
// BLYNK Functions
BlynkTimer timer; // initialise timer function
WidgetLED ledFan(V10);
WidgetLED ledbridgeData(V21); // bridgeData
#define LED_PIN 2
* Variables
float roofTempSensor;
float garageTempSensor;
float deltaTemp;
float maxRoofTemp = 0; // set initial values that will be corrected to current temp when first run
float minRoofTemp = 50;
float maxGarageTemp = 0;
float minGarageTemp = 50;
int fanPin = 4;
int timerFlag = 0;
boolean fanState = 0; // active high
int upperGarageTemp = 24; // stop fan when garage temperature reaches this value
bool bridgeData = HIGH; // holds data sent from another ESP32
pinMode(fanPin, OUTPUT);
* BLYNK Timers
timer.setInterval(9900L, readTemps);
* Set Sensor Resolution and check
sensors.setResolution(officeThermometer, 10);
sensors.setResolution(roofThermometer, 10);
delay(100);
Blynk.syncAll();
timer.run(); // run timers
* Functions
void readTemps()
sensors.requestTemperatures(); // Send the command to get temperatures from sensors ALL OF THEM
roofTempSensor = sensors.getTempCByIndex(1);
garageTempSensor = sensors.getTempCByIndex(0);
if((roofTempSensor > -100 && roofTempSensor < 85) && (garageTempSensor > -100 && garageTempSensor <85)) // disregard erroneous values
Blynk.virtualWrite(V7, roofTempSensor);
Blynk.virtualWrite(V6, garageTempSensor);
deltaTemp = roofTempSensor - garageTempSensor;
if (roofTempSensor > maxRoofTemp) maxRoofTemp = roofTempSensor; // update maxTemp
if (roofTempSensor < minRoofTemp) minRoofTemp = roofTempSensor; // update minTemp
if (garageTempSensor > maxGarageTemp) maxGarageTemp = garageTempSensor; // update maxTemp
if (garageTempSensor < minGarageTemp) minGarageTemp = garageTempSensor; // update minTemp
Blynk.virtualWrite(V35, maxRoofTemp);
Blynk.virtualWrite(V36, minRoofTemp);
Blynk.virtualWrite(V8, deltaTemp);
if(garageTempSensor <= upperGarageTemp) // only run code when temp < max Garage Temperature
if(roofTempSensor >= garageTempSensor + 2) // if roof is hoter than garage and Garage door is closed
if( bridgeData == LOW) {
digitalWrite (fanPin, LOW); // turn off Fan when door is open
ledFan.off();
else {
digitalWrite (fanPin, HIGH); // Fan on when door is closed
ledFan.on(); // fan on when roof is 1 degC hotter than garage
if(roofTempSensor <= garageTempSensor + 1.5)
ledFan.off(); // turn fan off when roof drops to 0 degC hotter than garage
{ // when roof temp exceeds upper limit
ledFan.off();
// Read Timer for resetting Max/Min temp values //////////////////////////
BLYNK_WRITE(V30) { // V30 is the Timer widget
if(param.asInt() == 1) { // Timer Widget set to 00:00
// if timer == midnight send Max/Min values to SuperChart, then reset values for next day
Blynk.virtualWrite(V31, maxRoofTemp);
Blynk.virtualWrite(V32, minRoofTemp);
Blynk.virtualWrite(V33, maxGarageTemp);
Blynk.virtualWrite(V34, minGarageTemp);
maxRoofTemp = 0; //reset maxRoofTemp
minRoofTemp = 50; //reset minRoofTemp
maxGarageTemp = 0; // reset maxGarageTemp
minGarageTemp = 50; // reset minGarageTemp
BLYNK_WRITE(V35)
// Use of syncAll() will cause this function to be called
// Parameter holds last maxRoofTemp value
maxRoofTemp = param.asFloat();
BLYNK_WRITE(V36)
// Parameter holds last minRoofTemp value
minRoofTemp = param.asFloat();
