I am making a Projekt with Micropython 1.19.1 on a m5stick c
I am using the Blynk app (the new one) on a iPhone.
I am using the libary from vshymanskyy.
It is possible to send text data to the app.
Amd to receive Data from the app
I assigned V9 as datastream to the superchart.
The App is getting always the value 255.
How can I get the app to get the values as float?
Thanks for your help.
# Wetterstation V2.1 14.10.2022 by O. Werner
# Wetterstation V2.0 by Olaf Werner
import m5stickc_lcd
import M5Stick
import ui
from time import sleep_ms
from machine import Pin, I2C, reset
import machine
import ENV
import time
import wlan
import _thread
import ubinascii
import BlynkLib as blynklib
lcd = m5stickc_lcd.ST7735()
lcd.set_rotate(m5stickc_lcd.ROTATE_90)
label1 = ui.label(lcd, 'Luftdruck: ', 2, 2, m5stickc_lcd.WHITE, m5stickc_lcd.MONACO12)
label2 = ui.label(lcd, 'Luftfeuchtigkeit: ',2, 20, m5stickc_lcd.WHITE, m5stickc_lcd.MONACO12)
label3 = ui.label(lcd, 'Temperatur: ',2, 40, m5stickc_lcd.WHITE, m5stickc_lcd.MONACO12)
i2c = I2C(1, scl = Pin(26), sda = Pin(0), freq = 100000)
dev1 = ENV.BMP280(i2c)
dev2 =ENV.DHT12(i2c)
BLYNK_AUTH = 'deleted'
def get_pressure(dev):
ret=0
for i in range(10):
ret += dev.pressure()
sleep_ms(200)
ret = ret / 10.0
return ret
def get_temperature(dev1, dev2):
ret = 0
for i in range(10):
temp1 = dev1.temperature()
dev2.measure()
temp2 = dev2.temperature()
ot = (temp1 + temp2)/2.0
sleep_ms(200)
ret += ot
ret = ret / 10.0
return round((ret-6.983),1)
def get_humidity(dev):
ret = 0
for i in range(10):
dev.measure()
ret += dev.humidity()
sleep_ms(400)
ret = ret / 10.0
return ret
def but_thread():
global buttons
while (True):
if (buttons.all_buttons() == (0, 0)):
raise Exception ('Programm terminated')
buttons=M5Stick.Button()
wlan.do_connect() # open WLAN
client_id = ubinascii.hexlify(machine.unique_id())
print(client_id)
print ('Connecting to Blynk server...')
blynk = blynklib.Blynk(BLYNK_AUTH)
@blynk.on("V*")
def blynk_handle_vpins(pin, value):
global _pin
global _value
print("V{} value: {}".format(pin, value))
_pin = pin
_value = value
# if (pin == 1):
# print('pin 1')
# label1.set_text('resetting')
# label2.set_text('-')
# label3.set_text('-')
# sleep_ms(1000)
# reset()
# elif (pin == 2):
# flag = False
def main_loop():
global flag
global buttons
global _pin
global _value
start = time.ticks_ms()
flag = True
while flag:
#print (buttons.all_buttons())
flag = not (buttons.all_buttons() == (0,0))
#print (flag)
now = time.ticks_ms()
blynk.run()
#print(str(_pin) + '-' + _value[0] )
if (_pin == '1') and (_value[0] == '1'):
sleep_ms(1000)
reset()
if (_pin == '2') and (_value[0] == '1'):
print('Programm beenden...')
flag = False
if (now-start > 600000):
print('Messung läuft...')
p = round(get_pressure(dev1)/100, 1)
t = get_temperature(dev1, dev2)
h = round(get_humidity(dev2), 1)
blynk.virtual_write(10, str(t) + ' °C')
blynk.virtual_write(11, str(p) + ' hPa')
blynk.virtual_write(12, str(h) + ' %')
blynk.virtual_write(9, p)
label1.set_text('P: ' + str(p))
label2.set_text('H: ' + str(h))
label3.set_text('T: ' + str(t))
if not(flag):
label1.set_text('Programmende')
time.sleep_ms(1000)
_pin = 0
_value = 'x'
#main_loop()
try:
main_loop()
except:
print('Fehler')
reset()
