SuperChart visual small problem
Dear Sirs, Dear @BlynkAndroidDev
I have discovered recently that there is a visual glitch in the SuperChart. Please see the self-explanatory video and let me know.
Thanks.
https://mega.nz/#!GwMmmYCB!fIO_H50CpWfJmWxn9YzaXRzZxOD7VapaQhMiPgHEV7A
Best Regards,
Mike Kranidis
Thanks for the report, we’'ll check it on our side.
HI Mike,
Can you share me you project, so I can try to reproduce this bug with your data? My email - alex@blynk.cc
Dear Alexander,
ofcourse I can share with you ( in your email ) my project, but the problem is not with the data but when i touch the SuperChart in any point, I can not clearly see the time at the specific point.
Do you still need my project sharing? It is only two click away !
I thought the issue is about not updating values in highlight bar for 2 streams?
I have already sent the sharing, see by yourself but the problem is as described in the message here.
Dear Alexander,
did you see the problem on your end?
Yep, I’ll upload tomorrow to the beta channel new build with fixes to current release
I’ve uploaded a new build with the same version - this issue should be fixed in it
Thanks a lot. When the updated version will be available on the play I will test it and I will let you know.
I confirm that the new release of the Android app is solving the reported problem. Thanks
