Superchart bug?
I think there might be a small bug in the mobile app superchart widget associated with the “connect missing points” selector. I have a variable in one of my apps that calculates once per day. Historically, when this charted, it would display the same values all day and then step change when the new value was calculated. Now, on the daily chart, I just get a single dot and when I chart over a day or longer, these single daily points are joined. Screenshots below show the single dot on the daily chart and the display over longer periods. You can see when the behaviour changed. I’m using Android.
Cheers
Steve
