Hi all
Long time lurker, first time poster.
I just thought I’d share a little headache I had with the new Styled button. I have a blynk controlled garage door opener. When the new Styled button came along I wanted to swap out the old ones to save some screen space.
The new button worked just fine but i could not make it change color (depending on door status)
After hours of hairpulling i found that instead of deleting the old button I had just moved it down (off the screen). This button used the same virtual pin and messed up the color changing code. After deleting this old button the styled button worked perfect.
