Student plan instead of pro
Is there any possibility to get a student plan or pro with a discount for educational purposes? I have project for my university that requires a mobile app just for presenting the measurments of air quality sensor connected to Raspberry Pi. But on the free plan i can’t even label the values that i would get from RPi. Showing only values without any labeling isn’t very presentable and it’s very confusing what is what. Thanks in advance for the help.
What exactly does this mean?
In example: I have a temperature sensor and it shows the value 10, and i can’t make a label above it with text “temperature”.
Is this an app widget or web widget?
If app, then iOS or Android?
Which widget type?
Screenshots would help!
Free plan should be more than enough for a project like this.
For a university project, I’d also try to keep the dashboard as simple as possible. If labels are the only issue, screenshots of the widget setup would definitely help because there may be an easier way to display the sensor names without needing a paid plan. Sometimes it’s just a matter of using a different widget or layout.
