Hey, new to Blynk. I decided to try a servo test with my Yun. I set it up and connected with the IP of my Yun. Auth token was correct. Ran the blynk server. Open the app and says its not connected. Compiles without a problem, and I upload from both the COM1 port and through WiFi. Doesnt work, what am I doing wrong? I am using the servo script from the library. Where there is an XX in the IP, is where I hidden the last numbers for the sake of posting this.
Rotate a servo using a slider!
App project setup:
Slider widget (0...180) on V3
#include <Ethernet.h>
#include <Servo.h>
char auth[] = "1f874bbd77dc4f8588b64b4ab6f7c8fd";
Servo servo;
BLYNK_WRITE(V3)
servo.write(param.asInt());
Blynk.begin(auth, IPAddress(192,168,1,XX), 8080);
servo.attach(9);
