Stroboscope with virtual pins
Hi there,
Can you please help me with the stroboscope script?
What if I want to control two different functions with two different buttons with the strobe script.
For example I want V1 & V2 to control D3, & and V3 & V4 to control D4?
I have only been able to control both D3 & D4 at the same time with either V1 or V2.
Hello. Please post your code and explain what you want to achieve with it so we could help. It is not very clear for me from description.
Have you tried looking at http://docs.blynk.cc/#blynk-main-operations-virtual-pins
Yes, of course.
I hope it is maybe somewhat clearer now.
Code:
#define LED_PIN1 3
#define LED_PIN2 4
int t1;
// Enable/disable blinking using virtual pin 1
BLYNK_WRITE(V1)
  if (param.asInt()) {
    timer.enable(t1);
    timer.disable(t1);
    digitalWrite(LED_PIN1, LOW);
// Change blink interval using virtual pin 2
BLYNK_WRITE(V2)
  long interval = param.asLong();
  boolean wasEnabled = timer.isEnabled(t1);
  timer.deleteTimer(t1);
  t1 = timer.setInterval(interval, ledBlynk);
  if (!wasEnabled) {
    timer.disable(t1);
BLYNK_WRITE(V3)
    timer.enable(t1);
    timer.disable(t1);
    digitalWrite(LED_PIN2, LOW);
BLYNK_WRITE(V4)
  if (!wasEnabled) {
    timer.disable(t1);
// Toggle LED
void ledBlynk()
  digitalWrite(LED_PIN1, !digitalRead(LED_PIN1));
  // Configure Blynk
  Blynk.begin(auth);
  // Configure LED and timer
  pinMode(LED_PIN1, OUTPUT);
  t1 = timer.setInterval(500L, ledBlynk);
  timer.disable(t1);
  pinMode(LED_PIN2, OUTPUT);
  timer.disable(t1);
@Erik_Hagstrom are you planning to use any Blynk libraries in your sketch?
Here is the libraries that are included in the sketch.
[quote]// You could use a spare Hardware Serial on boards that have it (like Mega)
#include <SoftwareSerial.h> //SoftwareSerial.h
SoftwareSerial SwSerial(2, 3); // RX, TX
#define BLYNK_PRINT SwSerial
#include <BlynkSimpleSerial.h> //BlynkSimpleSerial.h
#include <SimpleTimer.h> //SimpleTimer.h
[/quote]
invisible libraries, don’t you just hate them.
I don’t really know why they didn’t pop up, I added the names to them with // in front.
set a global variable of:
int t2;
and then change your V3 and V4 to use t2.
please learn how to format your sketches as it annoys the hell out of me to see such rubbish.
Study this until you can do it in your sleep Blynk.begin seems to change my long values. without Blynk.begin it work ok
Code snippets should be formatted. Please edit your initial post:
How to do that:
 ``` cpp <--put 3 backticks BEFORE your code starts  ("cpp" means C++ language)
   //Put your code here
 ``` <--insert 3 backticks AFTER your code
**This makes your code readable and with highlighted syntax, like this
//comment goes here
void helloWorld() {
   String message =  "hello" + "world";
Thanks,
Unfortunately I still have the same problem with V1 and V2 still triggers both LED_PIN1 and LED_PIN2, the same goes with V3 and V4.
char auth[] = "---";
#define LED_PIN1 3
#define LED_PIN2 4
int t1;
int t2;
BLYNK_WRITE(V1)
    timer.enable(t1);
    timer.disable(t1);
BLYNK_WRITE(V2)
  if (!wasEnabled) {
    timer.disable(t1);
BLYNK_WRITE(V3)
    timer.enable(t2);
    timer.disable(t2);
BLYNK_WRITE(V4)
  boolean wasEnabled = timer.isEnabled(t2);
  timer.deleteTimer(t2);
  t2 = timer.setInterval(interval, ledBlynk);
  if (!wasEnabled) {
    timer.disable(t2);
// Toggle LED
void ledBlynk()
  digitalWrite(LED_PIN2, !digitalRead(LED_PIN2));
  // Configure Blynk
  Blynk.begin(auth);
  timer.disable(t1);
  t2 = timer.setInterval(500L, ledBlynk);
  timer.disable(t2);
@Erik_Hagstrom take a look at the following sketch which is in ESP format rather than Arduino format. You just need to convert it back to Arduino for you to use. For the ESP I used LED_PIN1 and LED_PIN2 both as the onboard LED and it is active LOW.
// Stroboscope.ino mod by Costas 9/10/16
//#define BLYNK_DEBUG
char auth[] = "xxxxxxxxxxxxxxx";
#define LED_PIN1 2   // was 3 for Arduino
#define LED_PIN2 2   // was 4 for Arduino
int t1;
int t2;
BLYNK_WRITE(V1)
    timer.enable(t1);
    timer.disable(t1);
    digitalWrite(LED_PIN1, HIGH);  // LED active LOW
BLYNK_WRITE(V2)
  t1 = timer.setInterval(interval, ledBlynk1);
  if (!wasEnabled) {
    timer.disable(t1);
BLYNK_WRITE(V3)
    timer.enable(t2);
    timer.disable(t2);
    digitalWrite(LED_PIN2, HIGH);  // LED active LOW
    //digitalWrite(LED_PIN1, HIGH);  // LED active LOW
BLYNK_WRITE(V4)
  t2 = timer.setInterval(interval, ledBlynk2);
  if (!wasEnabled) {
    timer.disable(t2);
// Toggle LED_PIN1
void ledBlynk1()
  //digitalWrite(LED_PIN1, !digitalRead(LED_PIN1));
// Toggle LED_PIN2
void ledBlynk2()
  Serial.println("\nStarted");
  Blynk.begin(auth, "MTN WIFI 19996", "xxxxxx", "192.168.10.229", 8442);
  int mytimeout = millis() / 1000;
    if((millis() / 1000) > mytimeout + 4){ // try for less than 5 seconds
      break;
  if(Blynk.connected()){
    Serial.println("Connected to Blynk");
  else{
    Serial.println("Failed to connect to Blynk");
  digitalWrite(LED_PIN1, HIGH);  // on board LED off
  t1 = timer.setInterval(500L, ledBlynk1);
  timer.disable(t1);
  digitalWrite(LED_PIN2, HIGH);  // on board LED off
  t2 = timer.setInterval(500L, ledBlynk2);
  timer.disable(t2);
Thanks a lot, after some tweaking I finally got it to work just the way I want it.
Many many thanks @Costas
show us the tweaks!
@Dave1829 Absolutely! Here’s the sketch I’m using at the moment.
char auth[] = "xxxxxxxxxxxxxxxxxxxx";
#define LED_PIN1 3
#define LED_PIN2 4
int t1;
int t2;
BLYNK_WRITE(V1)
    timer.enable(t1);
    timer.disable(t1);
BLYNK_WRITE(V2)
  if (!wasEnabled) {
    timer.disable(t1);
BLYNK_WRITE(V3)
    timer.enable(t2);
    timer.disable(t2);
BLYNK_WRITE(V4)
  if (!wasEnabled) {
    timer.disable(t2);
// Toggle LED
void ledBlynk()
  // Configure Blynk
  Blynk.begin(auth);
  timer.disable(t1);
  timer.disable(t2);
