@Gunner, sorry i didn’t get it. Can you repeat, please?
OK…
AKA read that link I showed at around post #10 of this topic.
I don’t know if that would be an option or solution for you or not… depends on what you want accomplish and what you try I guess.
Was just going off your comment…
If it will not be a solution for you then no problem for me ![]()
@Gunner, trying to change the Properties, but nothing works, still not refreshing the image and not changing any properties like scaling, rotating, etc.
Have you seen this announcement?
Hi janek,
see this issue for usage with “set property” node or “image gallery” node:
https://github.com/gablau/node-red-contrib-blynk-ws/issues/11#issuecomment-474626815
let us know
thanks @gab.lau, @PeteKnight, @Gunner So far no luck, I updated the node (node-red-contrib-blynk-ws) a tried the recommended code with no result - the image is loaded at the start, but never updated. My nodered flow is:
[{"id":"993a10a.096037","type":"tab","label":"Blynk Local 1","disabled":false,"info":""},{"id":"5bed58b0.fd51c8","type":"inject","z":"993a10a.096037","name":"","topic":"timestamp","payload":"","payloadType":"date","repeat":"0.1","crontab":"","once":true,"onceDelay":"1","x":140,"y":100,"wires":[["3320257b.0e65c2","3d35cd04.b73c3a"]]},{"id":"3320257b.0e65c2","type":"debug","z":"993a10a.096037","name":"","active":true,"tosidebar":false,"console":false,"tostatus":true,"complete":"payload","x":370,"y":160,"wires":[]},{"id":"3d35cd04.b73c3a","type":"blynk-ws-out-write","z":"993a10a.096037","name":"","pin":0,"pinmode":0,"client":"5ba1ccbc.9461d4","x":350,"y":100,"wires":[]},{"id":"cd995a3c.eff658","type":"comment","z":"993a10a.096037","name":"Blynk local test 85e675fe1e544b46b20bbf260e323516","info":"85e675fe1e544b46b20bbf260e323516 ","x":220,"y":40,"wires":[]},{"id":"c6628745.81cee8","type":"http in","z":"993a10a.096037","name":"","url":"/snapshot","method":"get","upload":false,"swaggerDoc":"","x":100,"y":240,"wires":[["104fb14b.a801bf"]]},{"id":"104fb14b.a801bf","type":"file in","z":"993a10a.096037","name":"","filename":"/dev/shm/snapshot.jpeg","format":"","sendError":true,"x":330,"y":240,"wires":[["a5ecd675.8d47b8"]]},{"id":"a5ecd675.8d47b8","type":"change","z":"993a10a.096037","name":"Set Headers","rules":[{"t":"set","p":"headers","pt":"msg","to":"{}","tot":"json"},{"t":"set","p":"headers.content-type","pt":"msg","to":"image/jpeg","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":550,"y":240,"wires":[["5efb6cdb.ffc184","949fb2a3.2af188"]]},{"id":"5efb6cdb.ffc184","type":"http response","z":"993a10a.096037","name":"","statusCode":"","headers":{},"x":530,"y":280,"wires":[]},{"id":"c6f57f07.ed3e2","type":"exec","z":"993a10a.096037","command":"bash /opt/snapshot.sh","addpay":true,"append":"","useSpawn":"false","timer":"","oldrc":true,"name":"snapshot from RaspiCam","x":490,"y":440,"wires":[["d07d50e1.6be63"],["19d0ffbf.2fe158","3ccb8756.81e1d"],["98a1ec8c.8c9b68"]]},{"id":"949fb2a3.2af188","type":"blynk-ws-out-write","z":"993a10a.096037","name":"","pin":"1","pinmode":0,"client":"5ba1ccbc.9461d4","x":620,"y":180,"wires":[]},{"id":"f9c29027.ab491","type":"blynk-ws-style-btn","z":"993a10a.096037","name":"Snapshot","pin":"3","prop":0,"onlabel":"ON","offlabel":"OFF","oncolor":"#000000","onbackcolor":"#ffffff","offcolor":"#ffffff","offbackcolor":"#000000","client":"5ba1ccbc.9461d4","x":80,"y":480,"wires":[["96e1c2d3.a01aa8","1ad650fd.4c311f"]]},{"id":"96e1c2d3.a01aa8","type":"function","z":"993a10a.096037","name":"make snapshot","func":"if(msg.payload==1)\nreturn msg;","outputs":1,"noerr":0,"x":260,"y":480,"wires":[["c6f57f07.ed3e2"]]},{"id":"44595fb2.85abf","type":"blynk-ws-out-set-property","z":"993a10a.096037","name":"","pin":"1","pinmode":0,"prop":"bycode","client":"5ba1ccbc.9461d4","x":500,"y":320,"wires":[]},{"id":"3ccb8756.81e1d","type":"function","z":"993a10a.096037","name":"image property change","func":"msg = {}\nmsg.topic = \"bycode\";\nmsg.payload = \"not empty\";\nmsg.imgid=1; //index of image\nmsg.url=\"https://192.168.0.13:1880/snapshot\";\nreturn msg;","outputs":1,"noerr":0,"x":260,"y":380,"wires":[["601afc1.d08c404","44595fb2.85abf"]]},{"id":"601afc1.d08c404","type":"debug","z":"993a10a.096037","name":"","active":true,"tosidebar":true,"console":true,"tostatus":true,"complete":"true","x":450,"y":380,"wires":[]},{"id":"d07d50e1.6be63","type":"debug","z":"993a10a.096037","name":"","active":false,"tosidebar":false,"console":false,"tostatus":true,"complete":"payload","x":720,"y":440,"wires":[]},{"id":"19d0ffbf.2fe158","type":"debug","z":"993a10a.096037","name":"","active":false,"tosidebar":false,"console":false,"tostatus":true,"complete":"payload","x":710,"y":500,"wires":[]},{"id":"98a1ec8c.8c9b68","type":"debug","z":"993a10a.096037","name":"","active":false,"tosidebar":false,"console":false,"tostatus":true,"complete":"payload","x":720,"y":560,"wires":[]},{"id":"1ad650fd.4c311f","type":"debug","z":"993a10a.096037","name":"","active":true,"tosidebar":false,"console":false,"tostatus":true,"complete":"payload","x":260,"y":540,"wires":[]},{"id":"5ba1ccbc.9461d4","type":"blynk-ws-client","z":"","name":"Image Gallery","path":"wss://192.168.0.20:9443/websockets","key":"85e675fe1e544b46b20bbf260e323516","dbg_all":false,"dbg_read":false,"dbg_write":false,"dbg_notify":false,"dbg_mail":false,"dbg_prop":false,"dbg_sync":false,"dbg_bridge":false,"dbg_low":false,"dbg_pins":"","multi_cmd":true,"proxy_type":"no","proxy_url":"","enabled":true}]
Hi janek,
the problem I believe is no longer not node-red at this point.
From your flow I see that the url of the image is https://192.168.0.13:1880/snapshot but blynk caches images and if the link is always the same it does not update it.
A solution could be to give a unique name to the image like: https://192.168.0.13:1880/snapshot-20192103080000 simply adding the current date and time or the timestamp to filename.
let us know
@gab.lau, @PeteKnight, @Gunner - thank you for your support. I am able to make a snapshot from RaspiCam using Blynk on Android (simulator Bluestack 4), but not on my iPhone.
Attached is my NodeRed flow:
[{"id":"993a10a.096037","type":"tab","label":"Blynk Local 1","disabled":false,"info":""},{"id":"5bed58b0.fd51c8","type":"inject","z":"993a10a.096037","name":"","topic":"timestamp","payload":"","payloadType":"date","repeat":"0.1","crontab":"","once":true,"onceDelay":"1","x":140,"y":100,"wires":[["3320257b.0e65c2","3d35cd04.b73c3a"]]},{"id":"3320257b.0e65c2","type":"debug","z":"993a10a.096037","name":"","active":true,"tosidebar":false,"console":false,"tostatus":true,"complete":"payload","x":370,"y":160,"wires":[]},{"id":"3d35cd04.b73c3a","type":"blynk-ws-out-write","z":"993a10a.096037","name":"","pin":0,"pinmode":0,"client":"5ba1ccbc.9461d4","x":350,"y":100,"wires":[]},{"id":"cd995a3c.eff658","type":"comment","z":"993a10a.096037","name":"Blynk local test 85e675fe1e544b46b20bbf260e323516","info":"85e675fe1e544b46b20bbf260e323516 ","x":220,"y":40,"wires":[]},{"id":"c6628745.81cee8","type":"http in","z":"993a10a.096037","name":"","url":"/snapshot00","method":"get","upload":false,"swaggerDoc":"","x":100,"y":220,"wires":[["104fb14b.a801bf"]]},{"id":"104fb14b.a801bf","type":"file in","z":"993a10a.096037","name":"","filename":"/dev/shm/snapshot00.jpeg","format":"","sendError":true,"x":330,"y":220,"wires":[["a5ecd675.8d47b8"]]},{"id":"a5ecd675.8d47b8","type":"change","z":"993a10a.096037","name":"Set Headers","rules":[{"t":"set","p":"headers","pt":"msg","to":"{}","tot":"json"},{"t":"set","p":"headers.content-type","pt":"msg","to":"image/jpeg","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":530,"y":220,"wires":[["5efb6cdb.ffc184","949fb2a3.2af188"]]},{"id":"5efb6cdb.ffc184","type":"http response","z":"993a10a.096037","name":"","statusCode":"","headers":{},"x":750,"y":220,"wires":[]},{"id":"c6f57f07.ed3e2","type":"exec","z":"993a10a.096037","command":"bash /opt/snapshot.sh","addpay":true,"append":"","useSpawn":"false","timer":"","oldrc":true,"name":"snapshot from RaspiCam","x":490,"y":400,"wires":[["d07d50e1.6be63"],["19d0ffbf.2fe158","1a26d0a3.9dbdb7"],["98a1ec8c.8c9b68"]]},{"id":"949fb2a3.2af188","type":"blynk-ws-out-write","z":"993a10a.096037","name":"","pin":"1","pinmode":0,"client":"5ba1ccbc.9461d4","x":780,"y":160,"wires":[]},{"id":"f9c29027.ab491","type":"blynk-ws-style-btn","z":"993a10a.096037","name":"Snapshot","pin":"3","prop":0,"onlabel":"ON","offlabel":"OFF","oncolor":"#000000","onbackcolor":"#ffffff","offcolor":"#ffffff","offbackcolor":"#000000","client":"5ba1ccbc.9461d4","x":80,"y":480,"wires":[["96e1c2d3.a01aa8","1ad650fd.4c311f"]]},{"id":"96e1c2d3.a01aa8","type":"function","z":"993a10a.096037","name":"make snapshot","func":"if(msg.payload==1)\nreturn msg;","outputs":1,"noerr":0,"x":260,"y":480,"wires":[["c6f57f07.ed3e2"]]},{"id":"44595fb2.85abf","type":"blynk-ws-out-set-property","z":"993a10a.096037","name":"","pin":"1","pinmode":0,"prop":"bycode","client":"5ba1ccbc.9461d4","x":520,"y":760,"wires":[]},{"id":"3ccb8756.81e1d","type":"function","z":"993a10a.096037","name":"image property change","func":"var filename = msg.payload;\nmsg = {};\nmsg.topic = \"bycode\";\nmsg.payload = \"not empty\";\nif(filename == \"snapshot00.jpeg\")\n {\n msg.imgid=1;\n msg.url=\"http://192.168.0.13:1880/snapshot00\";\n }else\n {\n msg.imgid=2;\n msg.url=\"http://192.168.0.13:1880/snapshot01\"; \n }\nreturn msg;","outputs":1,"noerr":0,"x":220,"y":760,"wires":[["44595fb2.85abf","fdaf87b4.e9cc"]]},{"id":"d07d50e1.6be63","type":"debug","z":"993a10a.096037","name":"","active":false,"tosidebar":false,"console":false,"tostatus":true,"complete":"payload","x":720,"y":440,"wires":[]},{"id":"19d0ffbf.2fe158","type":"debug","z":"993a10a.096037","name":"","active":false,"tosidebar":true,"console":true,"tostatus":true,"complete":"payload","x":720,"y":500,"wires":[]},{"id":"98a1ec8c.8c9b68","type":"debug","z":"993a10a.096037","name":"","active":false,"tosidebar":false,"console":false,"tostatus":true,"complete":"payload","x":720,"y":560,"wires":[]},{"id":"1ad650fd.4c311f","type":"debug","z":"993a10a.096037","name":"","active":true,"tosidebar":false,"console":false,"tostatus":true,"complete":"payload","x":260,"y":540,"wires":[]},{"id":"d8de1f32.86d9f8","type":"debug","z":"993a10a.096037","name":"","active":false,"tosidebar":true,"console":true,"tostatus":true,"complete":"payload","x":640,"y":620,"wires":[]},{"id":"2897251f.59a67a","type":"inject","z":"993a10a.096037","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":true,"onceDelay":0.1,"x":110,"y":680,"wires":[["db385c95.41558"]]},{"id":"db385c95.41558","type":"function","z":"993a10a.096037","name":"Init flow variables","func":"flow.set('count', 0);\nflow.set('image01', \"\");\nflow.set('image02', \"\");","outputs":1,"noerr":0,"x":150,"y":640,"wires":[[]]},{"id":"1a26d0a3.9dbdb7","type":"function","z":"993a10a.096037","name":"toggle","func":"if (msg.payload)\n{\n var count = flow.get('count') || false;\n if (count === false)\n {\n count = true;\n msg.payload = \"snapshot00.jpeg\"\n }\n else\n {\n count = false;\n msg.payload = \"snapshot01.jpeg\"\n }\n \n flow.set('count', count); \n}\nreturn msg;","outputs":1,"noerr":0,"x":470,"y":620,"wires":[["d8de1f32.86d9f8","65c5e55a.dabd5c"]]},{"id":"65c5e55a.dabd5c","type":"fs-ops-move","z":"993a10a.096037","name":"toggle filename","sourcePath":"/dev/shm","sourcePathType":"str","sourceFilename":"snapshot.jpeg","sourceFilenameType":"str","destPath":"/dev/shm","destPathType":"str","destFilename":"payload","destFilenameType":"msg","link":false,"x":440,"y":700,"wires":[["4c9d033d.800224","3ccb8756.81e1d"]]},{"id":"4c9d033d.800224","type":"debug","z":"993a10a.096037","name":"","active":false,"tosidebar":true,"console":true,"tostatus":true,"complete":"payload","x":640,"y":700,"wires":[]},{"id":"fdaf87b4.e9cc","type":"debug","z":"993a10a.096037","name":"","active":false,"tosidebar":true,"console":true,"tostatus":true,"complete":"true","x":430,"y":820,"wires":[]},{"id":"e31fdae9.7030b","type":"file in","z":"993a10a.096037","name":"","filename":"/dev/shm/snapshot01.jpeg","format":"","sendError":true,"x":330,"y":280,"wires":[["a41ed02a.d703a"]]},{"id":"c42d9ec0.c49e68","type":"http in","z":"993a10a.096037","name":"","url":"/snapshot01","method":"get","upload":false,"swaggerDoc":"","x":100,"y":280,"wires":[["e31fdae9.7030b"]]},{"id":"a41ed02a.d703a","type":"change","z":"993a10a.096037","name":"Set Headers","rules":[{"t":"set","p":"headers","pt":"msg","to":"{}","tot":"json"},{"t":"set","p":"headers.content-type","pt":"msg","to":"image/jpeg","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":530,"y":280,"wires":[["5efb6cdb.ffc184","113aff0f.5cc2b9"]]},{"id":"113aff0f.5cc2b9","type":"blynk-ws-out-write","z":"993a10a.096037","name":"","pin":"1","pinmode":0,"client":"5ba1ccbc.9461d4","x":760,"y":300,"wires":[]},{"id":"5ba1ccbc.9461d4","type":"blynk-ws-client","z":"","name":"Image Gallery","path":"wss://192.168.0.20:9443/websockets","key":"85e675fe1e544b46b20bbf260e323516","dbg_all":false,"dbg_read":false,"dbg_write":false,"dbg_notify":false,"dbg_mail":false,"dbg_prop":false,"dbg_sync":false,"dbg_bridge":false,"dbg_low":false,"dbg_pins":"","multi_cmd":true,"proxy_type":"no","proxy_url":"","enabled":true}]
Cheers,
Janek
Is there an update for iOS in a pipeline?
Are you part of the iOS beta programme?
no, what is involved?
The link to get ios beta builds is the same and public, I’m not adding testers individually anymore.
