Hello Ristomatti. I went to stickbreaker’s GitHub, and after reading through his explanations, I am now using his code. As of now, I have the ESP32, CCS811 and the OLED display working with Blynk with no failures for two days now! Before, the longest was about 2 hours. Thank you very much for your suggestions.
Hello Flyindon.
You could explain how you have incorporated the stickbreaker code in your program.
Hi BlackTiger,
Get the files you need from github at:
get wire folder and copy to Arduino/arduino-esp32
copy esp32 to Arduino/arduino-esp32/cores
To be safe, I would recommend renaming the old cores and old Wire folders just in case something blows up. Stickbreaker says this is a Beta version, so things may change and blow your stuff up.
Also, I am running into a bit of a problem in that I get a random failure every day or so. I think I may have a noise issue on the i2C bus, so I am going to clean up the board and keep monitoring this.
Here are some links to the background information that I found useful:
Good luck.
Don
background info
covers bus busy issues
@flyindon Great to hear that it helped! I haven’t actually ended needing it but your post just reminded me about this. It’s useful to occasionally check the arduino-esp32 GitHub issue threads to see how things are progressing.
thanks for your help flyindon.
Greetings BlackTiger
Hi flyindon,
I’m suffering a similar problem to that you describe. I have an ESP32 monitoring analog (light, wind-speed and temperature) and digital (temperature, humidity, barometric pressure) sensors for environmental monitoring. The program runs fine without Blynk (i.e. reporting to the serial port). When I implement Blynk, it disconnects from the wifi randomly, and the serial output shows that it hangs on one of the digital sensors (suggesting an I2C issue). If I comment out the digital sensors, and just monitor the analog sensors, Blynk runs with no problems. Your solution sounds like the right thing, but I’m not sure how to implement it. I can’t see how to download files from the Github links that you indicate above. What am I missing? I’m a newbie at this, so thanks for steering me in the right direction.
Michael,
I am out of town for a few days and away from my computer. I understand that Stickbreaker’s fixes hace been incorporated into espressif, so get the update from espressif. If you still have problems, I can try to help later this week.
Don
Don,
Thanks so much. I do have a very recent espressif implementation, so I guess that the Stickbreaker’s fixes are already in. In the meantime I believe that I have found a fix, or at least a work-around. My initial sketch called ‘readSensors’ as a function that read each sensor and wrote its value to a Blynk virtual pin sequentially. I wondered if the BlynkWrite function at the end of each sensor ‘module’ interfered with the I2C timing, so I placed all the BlynkWrite commands after reading all the sensors. So far no disconnect, so that’s good. Whether my reasoning is sound, I’m not sure, but the net result is what I hoped for. Thanks for your offer to help.
Michael
I have a very similar issue at the moment.
I’m using an OLED with relevant Adafruit Libraries to display my Can Bus Data onto the OLED and send it to Blynk for remote monitoring.
I went to a friend’s house to demo the software and was met with an OLED that displays absolute garbage - obviously my ESP32 didn’t connect to his network.
I started my software back at my place and double checked that everything is working, which it was until I switched off my wifi router.
I’m making use of Blynk v2.0.
I’m a bit confused as to how the blink library can cause timing issues on the I2C.
My Can Bus as well as my FreeRTOS tasks are running as should when the wifi is disconnected, any advice on what to try?
Are you using the Edgent example?
Correct.
You should read this…
especially the “Defining your physical switch and LED” section, then check that you don’t have a GPIO conflict.
Thanks.
I went through the article, and made two adjustments in the Settings.h
file:
#else
// Custom board configuration
#define BOARD_BUTTON_PIN 0 // Pin where user button is attached
#define BOARD_BUTTON_ACTIVE_LOW true // true if button is "active-low"
#define BOARD_LED_PIN 27 // Set LED pin - if you have a single-color LED attached
//#define BOARD_LED_PIN_R 27 // Set R,G,B pins - if your LED is PWM RGB
//#define BOARD_LED_PIN_G 26
//#define BOARD_LED_PIN_B 25
//#define BOARD_LED_PIN_WS2812 33 // Set if your LED is WS2812 RGB
#define BOARD_LED_INVERSE false // true if LED is common anode, false if common cathode
#define BOARD_LED_BRIGHTNESS 64 // 0..255 brightness control
#endif
I’m making use of the ESP32 DevKit v4.
My code reacts in exactly the same manner as explained above:
When the Wifi connection drops, the OLED immediately displays garbage.
I have noticed the following in ConfigMode.h
void enterError()
BlynkState::set(MODE_ERROR);
unsigned long timeoutMs = millis() + 10000;
while (timeoutMs > millis() || g_buttonPressed)
app_loop();
if (!BlynkState::is(MODE_ERROR)) {
DEBUG_PRINT("Restarting after error.");
restartMCU();
When the wifi connection is restored, and only after the MCU restarts, the MCU reconnects to the blynk server and my OLED displays the information correctly.
I have tested this theory by commenting the //restartMCU();
function - the MCU does not restart, the OLED displays garbage and it does not reconnect to the blynk server.
My Can Bus and other RTOS related tasks run without errors.
What will cause the processor to enter the error state and cause my I2C to be affected?
Thanks,
Shawn
I meant GPIO conflicts within the sketch - Edgent trying to use the same GPIOs as your code.
Hi Pete, I have a question.
I noticed that my ESP32 does not reconnect to the wifi after the connection has been restored.
Instead it enters the default error state:
void run()
app_loop();
switch (BlynkState::get())
case MODE_WAIT_CONFIG:
case MODE_CONFIGURING: enterConfigMode(); break;
case MODE_CONNECTING_NET: enterConnectNet(); break;
case MODE_CONNECTING_CLOUD: enterConnectCloud(); break;
case MODE_RUNNING: runBlynkWithChecks(); break;
case MODE_OTA_UPGRADE: enterOTA(); break;
case MODE_SWITCH_TO_STA: enterSwitchToSTA(); break;
case MODE_RESET_CONFIG: enterResetConfig(); break;
default: enterError(); break;
Serial.println(BlynkState::get());
I changed the timeout time to 30000ms in hopes that it will reconnect, but no luck. The processor restarts.
void enterError()
unsigned long timeoutMs = millis() + 30000;
app_loop();
restartMCU();
I’ve also noticed that this line of code sets the status to error, but it’s not checked within BlynkEdgent.h:
- where is this mode checked?
My other question is, what might cause the processor to stay in the error mode? I see that app_loop();
method/function is called after every 10ms, but I don’t see any related code within the app_loop();
to reconnect once the connection has been lost nor any other related code which might clear the error.
In the original sketch, it is just the timer that runs:
void app_loop()
In my sketch, I have added my Can Bus task, my Relay Task and my Scheduler. I will remove these and add them to their own RTOS tasks, but doubt this is the reason why my ESP stays in the error mode:
Edgent BlynkEdgent;
BlynkTimer timer3;
void app_loop()
can_rx();
timer3.run();
relay1Task();
//manual_control();
startScheduler();
Thanks,
Shawn
Are you using EEPROM, SPIFFS, LittleFS etc. in your custom code?
Hi Pete,
None of the above.
It’s just I2C, Can Bus and my GPIO’s set as inputs and outputs.
I read an article on RandomNerdTutorials on which pins can and can’t be used and believe I utilized them correctly.
I also noticed that my LED does not flash when the wifi is disconnected - just noticed from a tutorial that the LED will flash when the wifi is not connected on the ESP.
Thanks,
Shawn
