I am using a CCS811 VOC and CO2 sensor, a BMP Pressure and Temperature sensor and an Adafruit SSD1306 OLED display with an Adafruit ESP32 Huzzah. All the sensors and display use i2c communications. If I run my code in the âstand aloneâ mode, i.e. not using Blynk, everything works fine. If I use Blynk, after some minutes up to several hours of operation, I get the following i2c errors:
[esp32-hal-i2c.c:161] i2cWrite():Busy Timeout! Addr:5b.
[esp32-hal-i2c.c:161] i2cWrite():Busy Timeout! Addr:40.
I tried removing the display â same result.
I removed one sensor and removed the display â same result with Blynk.
I have read in other forums that the i2c on the ESP32 has some problems with timing but the fact that it works without Blynk leads me to believe that I must be doing something wrong with Blynk.
My code is below. I cleaned it up a bit by removing some of the functions to make it easier to read and this code works without Blynk and fails with Blynk.
Read the TVOC and CO2 values from the SparkFun CSS811 breakout board
Originally derived from Sparkfun ESP32 Thing example
#include <arduino.h>
#include "SparkFunCCS811.h"
#include <Wire.h> //Classes for I2C
#include <Adafruit_GFX.h> //Classes for display
#include <Adafruit_SSD1306.h> //Classes for OLED display
* The following lines are for connecting to Blynk
#include <WiFi.h> //
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
// This is my authorization code for Blynk
char auth[] = âxxxxxxxxxâ;
//Put router info here
char ssid[] = âxxxxxxxxxâ;
char pass[] = âxxxxxxxxxxâ;
#define OLED_RESET 4
Adafruit_SSD1306 display(OLED_RESET);
#define CCS811_ADDR 0x5B //Default I2C Address for the CCS811
//#define CCS811_ADDR 0x5A //Alternate in case I have a conflict with others
CCS811 SensorOBJ(CCS811_ADDR); //Sensor object of class CCS811
long chipid; //used if I want to display chip identification code
long NewTime = 0; //upddated millisecond count
int GoofOff = 50; //delay time in milliseconds
void oledDisplay(); //function prototype declaration
void sendSensor(); //function prototype declaration
display.begin(SSD1306_SWITCHCAPVCC, 0x3C); // initialize with the I2C addr 0x3C (for the 128x32)
CCS811Core::status returnCode = SensorOBJ.begin(); // used for error codes
Serial.print("begin exited with: ");
Serial.println();
display.clearDisplay();
Blynk.begin(auth, ssid, pass); // start up Blynk
// this uploads data from sensor to Blynk at 1 second intervals
//timer.setInterval(2307L, oledDisplay); // skew timer interval to stop i2c issues
//call function if Blynk is disabled
//oledDisplay();
//delay(1000);
void oledDisplay(){
SensorOBJ.readAlgorithmResults(); //get data from Sensor
display.setTextSize(2);
display.setTextColor(WHITE);
display.setCursor(0,0);
display.print("TVOC: ");
display.println( SensorOBJ.getTVOC());
display.print("CO2: ");
display.println( SensorOBJ.getCO2());
display.display(); //Write data to oled
//display.clearDisplay();
void sendSensor(){
if (SensorOBJ.dataAvailable()){
Serial.println("Sending Data");
int C = SensorOBJ.getCO2();
int V = SensorOBJ.getTVOC();
Blynk.virtualWrite(V0, C);
Blynk.virtualWrite(V1, V);
Could someone give me an idea as to what I should do?
Thank you
