Hi Everyone,
I want to control a stepper motor via the Blynk app.
Press button 1 it rotates clockwise (const int stepsPerRevolution = 32 for full rotation)
Press button 2 it rotates anti clockwise.
I am using a TTGO T-Beam but only using the wifi functionso its basically an ESP32 Dev.
I am looking to adapt some existing code to get my project working and have googled/tried my hardest to get it working.
I have the below code working so everything is turning but I just want control via the app.
All help is GREATLY appreciated!
Stepper Motor Control - one revolution
This program drives a unipolar or bipolar stepper motor.
The motor is attached to digital pins 8 - 11 of the Arduino.
The motor should revolve one revolution in one direction, then
one revolution in the other direction.
Created 11 Mar. 2007
Modified 30 Nov. 2009
by Tom Igoe
#include <Stepper.h>
const int stepsPerRevolution = 32; // change this to fit the number of steps per revolution
const int stepsPerGearedRev = 32*64; // change this to fit the number of steps per revolution
// for your motor
// initialize the stepper library on pins 8 through 11:
Stepper myStepper(stepsPerRevolution, 2, 14, 13, 25);
// set the speed at 120 rpm:
myStepper.setSpeed(120);
// initialize the serial port:
// step one revolution in one direction:
Serial.println("clockwise");
myStepper.step(stepsPerGearedRev);
delay(500);
// step one revolution in the other direction:
Serial.println("counterclockwise");
myStepper.step(-stepsPerGearedRev);
delay(500);
I’d suggest that you restructure your code to clean-up your void loop and use timers, and get rid of all the delays before you think about adding any Blynk functionality.
Hey Gunner,
I have my stepper still rotating so I know the pins are ok but I am not able to get the app working still.
Code compiles, device comes online but not moving.
Any ideas?
App is setup as per your instructions
#define BLYNK_PRINT Serial // This prints to Serial Monitor
#include <WiFi.h> // for ESP32
#include <WiFiClient.h> // for ESP32
#include <BlynkSimpleEsp32.h> // for ESP32
#include <ESPmDNS.h> // For OTA w/ ESP32
#include <WiFiUdp.h> // For OTA
#include <ArduinoOTA.h> // For OTA
char auth[] = "xxx";
char ssid[] = "xxx";
char pass[] = "xxx";
char server[] = "blynk-cloud.com"; // URL for Blynk Cloud Server
int port = 8080;
const int stepsPerRevolution = 8; // change this to fit the number of steps per revolution for your motor
// ESP8266 use GPIO pin designation, not silk-screened labeling
// Stepper myStepper(stepsPerRevolution, 5, 4, 0, 2); // ESP8266 - initialize the stepper library for IN1, IN2, IN3, IN4
// ESP32 GPIO/Silk-screened pin designation
Stepper myStepper(stepsPerRevolution, 2, 14, 13, 25); // ESP32 - initialize the stepper library for IN1, IN2, IN3, IN4
int motorSpeed;
int motorDirection;
timer.setInterval(10, stepperControl); // This here is all the fancy timing part... it just updates the stepper control every 5ms
WiFi.begin(ssid, pass);
Blynk.config(auth, server, port);
Blynk.connect();
ArduinoOTA.handle(); // For OTA
BLYNK_CONNECTED() {
Blynk.syncVirtual(V0, V1);
BLYNK_WRITE(V0) { // Motor Speed - Slider set with 0-100 and Send On Relese OFF
motorSpeed = param.asInt();
myStepper.setSpeed(motorSpeed);
BLYNK_WRITE(V1) { // Motor Direction - Button set as Switch with 0-1
motorDirection = param.asInt();
void stepperControl() {
if (motorSpeed > 0) {
if (motorDirection == 0) { // Rotate Clockwise
myStepper.step(stepsPerRevolution / 100);
} else { // Rotate CounterClockwise
myStepper.step(-stepsPerRevolution / 100);
Sorry, I do not do private consulting, nor have the time/energy for much more work in this forum at this time, so I moved your question back here for others to assist with.
Also, formatting code is done with three backticks, not commas I fixed yours.
PS, change you AUTH code and don’t show the new one… else others will try to spin your stepper
