I have done my first stepper motor controller using WEMOS D1 mini pro + DRV8834 Low-Voltage Stepper Motor Driver Carrier
Because it is not possible to user the timer interrupt library I need to find a other solution.
May be it some one find this helpful for his project.
Social networks: http://www.fb.com/blynkapp
http://twitter.com/blynk_app
This example runs directly on ESP8266 chip.
Used Hardware:
Please be sure to select the right ESP8266 module
in the Tools -> Board menu!
char auth[] = "your auth";
char ssid[] = "your ssid";
char pass[] = "your pass";
#define DIR_PIN D0
#define STEP_PIN D3
#define ENABLE_PIN D4
#define DISABLE HIGH
#define ENABLE LOW
#define int_period 500L // [µsec] time to next interrupt
#define m_step_count_down_time 4 // m_step_count_down_time*int_period[msec] count down timer to disable motor driver minimum time the stepper needs to perform one step keep it low to save current
int steps = 0; // # of steps to be performed
int Periode = 2000; // [µsec] !!! period time to next step
int Next_Step = Periode;// [µsec] !!! count down timer current step
int m_step_count_down = 0;//[0,5msec]!!! count down timer to disable motor driver
int RUN=LOW ; //if set t0 HIGH the motor will run for ever
{ Serial.begin(9600);
pinMode (ENABLE_PIN , OUTPUT);
digitalWrite(ENABLE_PIN, DISABLE); // disable motor driver_2
pinMode (STEP_PIN , OUTPUT);
digitalWrite(STEP_PIN, LOW);
pinMode (DIR_PIN , OUTPUT);
noInterrupts();
timer0_isr_init();
timer0_attachInterrupt(timer0_ISR);
timer0_write(ESP.getCycleCount() + 80000000L); // 80MHz == 1sec
interrupts();
if(RUN==HIGH)steps=100; // Run for ever
BLYNK_WRITE(V1)
Periode = param.asInt() ; // assigning incoming value from pin V1 to a variable
if (Periode<int_period) Serial.printf("Error Periode lower than int_period ");
BLYNK_WRITE(V2)
steps = param.asInt();// assigning incoming value from pin V2 to a variable
BLYNK_WRITE(V3)
RUN = param.asInt(); // assigning incoming value from pin V3 to a variable
void timer0_ISR (void)
timer0_write(ESP.getCycleCount() + int_period * 80 ); //40000L); // 80MHz == int_period[msec]
if (m_step_count_down-- <= 1) digitalWrite(ENABLE_PIN, DISABLE); // disable motor driver when step is performed
if (steps > 0) // are there steps to be performed ?
Next_Step -= int_period ; // [µs];
if (Next_Step <= Periode) //[µsec]period time to next step
digitalWrite(ENABLE_PIN, ENABLE); // enable motor driver
Next_Step += Periode; // Next_Step = Next_Step + Periode;
digitalWrite( STEP_PIN, LOW);
steps--; // it will decrement two times when performing one single step
m_step_count_down = m_step_count_down_time ; // m_step_count_down_time*int_period[msec] count down timer to disable motor driver
digitalWrite( STEP_PIN, HIGH);// perform one step
