I have project for my off-grid solar system. Arduino messures battery bank voltage and when batteries are full, then Arduino turns on relay, which turns on power relay, which turns on 24V heating element for water tankt. And of course I am using Blynk to see what heppens in my garage.
I am using Ardiuno uno + ESP8266, software serial connection
Android 8.0.0, latest Blynk version. I use Blynk server.
Everything worked fine. But I decided to add StepH widget to change target Volts variable. And now Blynk after random time says - Your Project is Offline, in serial output I can see long Blynk PING. The problem startet when I added BLYNK_WRITE section to my code. The problem is related to RelejaSlegsana() function, because when I commented all lines (Blink.virtulalWrite and Blynk.notify) in my code, then it works.
This is working code, but I would like to have Blynk functions in my RelejaSlegsana() function.
I hope you can help me.
//Temperaturas sensoram
#include <OneWire.h>
#define ONE_WIRE_BUS 4
float Temperatura=0.00;
//Voltmetram un relejam
float MerkjaVolti=27.50; // Pie cik voltiem iesleegties relejam
float Stepvalue=27.50;
float voltage = 0.00;
float Volti=0.00;
float R1 = 100000.0; // resistance of R1 (100K)
float R2 = 10000.0; // resistance of R2 (10K)
int analog_value = 0; //voltmetra arduino pin
int sledzis = 0; //sledza stavoklis
int iii=0; //iesleegta releja ciklam
//Blynk darbibai
#include <ESP8266_Lib.h>
// Blynk autorizacijas tokens
char auth[] = "---";
char ssid[] = "---";
char pass[] = "---";
// Your ESP8266 baud rate:
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
void myTimerEvent()
void TemperaturasNolasisana()
Temperatura=sensors.getTempCByIndex(0);
Blynk.virtualWrite(V0, Temperatura);
Serial.print ("Temperatura ");
Serial.print (Temperatura);
Serial.print('\n');
void VoltuMerisana()
analog_value = analogRead(A0); // read the value at analog input pin A0
voltage = (analog_value * 5) / 1024.0;
Volti = voltage / (R2/(R1+R2));
if (sledzis==1){Volti=Volti-0.2;}
if (sledzis==0){Volti=Volti+0.2;}
Blynk.virtualWrite(V1, Volti);
Blynk.virtualWrite(V4, MerkjaVolti);
Serial.print ("Volti ");
Serial.print (Volti);
Serial.print('\n');
void RelejaSlegsana()
if (Volti >= MerkjaVolti)
digitalWrite(8, LOW);//iesleedz sleedzi
sledzis = 1;
//Blynk.virtualWrite(V2, "Relejs ON");
//Blynk.notify("Relejs ON");
Serial.print ("Relejs ON ");
Serial.print('\n');
for (iii=0; iii <= 300; iii++)
TemperaturasNolasisana();
VoltuMerisana();
//Blynk.virtualWrite(V3, iii);
Serial.print (iii);
Serial.print('\n');
//Blynk.notify("Relejs OFF");
digitalWrite(8, HIGH);//izsleedz sleedzi
//Blynk.virtualWrite(V2, "Relejs OFF");
//Blynk.virtualWrite(V3, "--");
Serial.print ("Relejs OFF ");
Serial.print('\n');
sledzis = 0;
//Blync--------
// Set ESP8266 baud rate
delay(30);
//Blynk.begin(auth, wifi, ssid, pass, "blynk-cloud.com", 8442);
//Blynk.begin(auth, wifi, ssid, pass, IPAddress(192,168,1,100), 8442);
//Voltmetrs---------
Serial.println("DIGITAL VOLTMETER");
Serial.print ("Meerkja Volti ");
Serial.print (MerkjaVolti);
Serial.print('\n');
Blynk.virtualWrite(V9, MerkjaVolti);
sensors.begin(); //temp sensoram
pinMode(8, OUTPUT); // Releja PIN
digitalWrite(8, HIGH); //izsleedz sleedzi
BLYNK_WRITE(V9) // Step widget set to 0.1 steps
MerkjaVolti = param.asFloat(); // Get value as float
Serial.println(String("stepValue = ") + MerkjaVolti);
//delay (1000);
delay (1000);
VoltuMerisana();
//delay (1000);
RelejaSlegsana();
//BLYNK_WRITE();
// delay (3000);
// to avoid delay() function!
