dear community,
I have two Arduino home control systems remotely controlled through the Blynk server. Both are connected to different Internet Service Provided (Telenet and Proximus - Belgium), are located in two different physical locations (100 km apart from each other) and running very different SW. They are both monitored by an separate co-located Nano and restarted (power cycled) after loss of connectivity from the Blynk server for 3 min. I installed this watchdog as I have found the systems “not-reachable” in some occasions, the hard reboot does solve those. This happens now and then, sometimes once a day, sometimes once a week but I have never seen both systems restarting concurrently (but don’t know neither if they are connected to the same server instance°.
As soon as the Arduino’s and they Ethernet shields are power cycled, they reconnect immediately to the Blank server in 90% of the cases, sometimes it takes them a couple of retries.
There is a ton of reasons why this could happen, bad HW, SW bugs, Network instabilities etc but before going into more detailed evaluations, I was wondering if there are any stats around on the Blank service availability (as this could be a reason as well even if I do have my doubts).
As the watchdog with power-cycle does get me out of troubles, this situation is not urgently asking for a solution but I would like to diagnose and understand the real issue in the end.
So as a start, the question for this tread is “are there any stats around on the Blank service availability”.
Thanks for your help.
