Hello, I’m trying to make a simple menu, where I choose a rate and it shows me certain values according to what I chose, and triggers a link to an internet page.
Could someone guide me because after several menu choices the program crashes and overflow appears!?
APP:
Error:
Thanks.
My CODE:
#define APP_DEBUG
#define USE_NODE_MCU_BOARD
#include "BlynkEdgent.h"
#include <RF24Network.h>
#include <RF24.h>
#include <nRF24L01.h>
#include <EEPROM.h>
#include <WidgetRTC.h>
WidgetRTC rtc;
WidgetLED led1(V6);
WidgetLED led2(V7);
WidgetLED led3(V17);
WidgetLED led4(V18);
WidgetLCD lcd(V36);
RF24 radio(D2, D8); // CE, CSN
RF24Network network(radio);
const uint16_t this_node = 00; // Address of this node in Octal format ( 04,031, etc)
const uint16_t node01 = 01;
const uint16_t node02 = 02;
const uint16_t node03 = 03;
const uint16_t node04 = 04;
const uint16_t node05 = 05;
float data[7];
#define EEPROM_SIZE 256
int ID1=0,ID2=0,ID3=0,ID4=0,ID5=0,ID6=0,ID7=0,ID8=0,ID9=0;
int BanderaSeleccionMenuArtefacto;
int flagSubsidio;
const int dirEnergiaT = 0;
int dirE1 = 10;
int dirE2 = 20;
int dirC1 = 30;
int dirC2 = 40;
float auxE1=0, auxE2=0, auxE3=0, auxE4=0, auxE5=0, Etotal=0;
float auxC1, auxC2, auxC3, auxC4, auxC5, auxCtotal;
int currentMenu; // Used to track which menu is in use
int MenuIndexID; // Used to track which menu item has been selected in the current menu
int Modo;
BLYNK_WRITE(V32){//select from APP
ID1=param.asInt();
if (ID1==1){
flagSubsidio=1;
else if (ID1==2){
flagSubsidio=2;
else if (ID1==3){
flagSubsidio=3;
BLYNK_WRITE(V40){//tab
ID3=param.asInt();
if (flagSubsidio==1){// BAJOS INGRESOS
switch (ID3){
case 1:{
Blynk.virtualWrite(V33,0.01);//KWh estimado
Blynk.virtualWrite(V34,7);//KWh mes estimado
Blynk.virtualWrite(V35,121); //costo estimado
break;
case 2:{
Blynk.virtualWrite(V33,0.05);//KWh estimado
Blynk.virtualWrite(V34,37);//KWh mes estimado
Blynk.virtualWrite(V35,299); //costo estimado
break;
case 3:{
Blynk.virtualWrite(V33,0.08);//KWh estimado
Blynk.virtualWrite(V34,58);//KWh mes estimado
Blynk.virtualWrite(V35,423); //costo estimado
break;
case 4:{
Blynk.virtualWrite(V33,0.03);//KWh estimado
Blynk.virtualWrite(V34,22);//KWh mes estimado
Blynk.virtualWrite(V35,210); //costo estimado
break;
default:
break;
else if (flagSubsidio==2){// MEDIOS INGRESOS
switch (ID3){
case 1:{
break;
case 2:{
break;
case 3:{
break;
case 4:{
break;
default:
break;
else if (flagSubsidio==3){// MAYORES INGRESOS
switch (ID3){
case 1:{
Blynk.virtualWrite(V35,159); //costo estimado
break;
case 2:{
Blynk.virtualWrite(V35,501); //costo estimado
break;
case 3:{
Blynk.virtualWrite(V35,740); //costo estimado
break;
case 4:{
Blynk.virtualWrite(V35,330); //costo estimado
break;
default:
break;
BanderaSeleccionMenuArtefacto=2;
consejos();
void consejos(){//PIN V38
if (BanderaSeleccionMenuArtefacto==0){
Blynk.setProperty(V38, "offImageUrl", "https://i.postimg.cc/BbMt903V/Consejos.png");
else if (BanderaSeleccionMenuArtefacto==1){//ILUMINACION
Blynk.setProperty(V38, "offImageUrl", "https://i.postimg.cc/XqVXzvR5/1BIS-PS.png");
Blynk.setProperty(V38, "url", "https://wordpress.com/2022/12/04/iluminacion/");
else if (BanderaSeleccionMenuArtefacto==2){//REFRIGERACION
Blynk.setProperty(V38, "offImageUrl", "https://i.postimg.cc/g2rLpnnq/2BIS-PS.png");
Blynk.setProperty(V38, "url", "https://wordpress.com/2022/12/04/refrigeracion/");
else if (BanderaSeleccionMenuArtefacto==3){ //LINEA BLANCA
Blynk.setProperty(V38, "offImageUrl", "https://i.postimg.cc/RZ86Z4tr/3BIS-PS.png");
Blynk.setProperty(V38, "url", "https://wordpress.com/2022/12/04/linea-blanca/");//puede ir cada uno a una foto.
else if (BanderaSeleccionMenuArtefacto==4){ //COCINA
Blynk.setProperty(V38, "offImageUrl", "https://i.postimg.cc/qRczwK50/4BIS-PS.png");
Blynk.setProperty(V38, "url", "https://wordpress.com/2022/12/04/cocina/");
else if (BanderaSeleccionMenuArtefacto==5){ //CLIMATIZACION
Blynk.setProperty(V38, "offImageUrl", "https://i.postimg.cc/nVYDYyy7/5BIS-PS.png");
Blynk.setProperty(V38, "url", "https://wordpress.com/2022/12/04/climatizacion/");
else if (BanderaSeleccionMenuArtefacto==6){//ELECTRONICA
Blynk.setProperty(V38, "offImageUrl", "https://i.postimg.cc/sDjZnnzL/6BIS-PS.png");
Blynk.setProperty(V38, "url", "https://wordpress.com/2022/12/04/electronica-audio-y-video/");
else if (BanderaSeleccionMenuArtefacto==7){//CUIDAD PERSONAL
Blynk.setProperty(V38, "offImageUrl", "https://i.postimg.cc/7YKJjgYZ/7BIS-PS.png");
Blynk.setProperty(V38, "url", "https://wordpress.com/2022/12/04/cuidado-personal/");
else if (BanderaSeleccionMenuArtefacto==8){///AGUA
Blynk.setProperty(V38, "offImageUrl", "https://i.postimg.cc/NMvKRDbp/8BIS-PS.png");
Blynk.setProperty(V38, "url", "https://wordpress.com/2022/12/04/agua/");
BLYNK_CONNECTED(){
rtc.begin();
BanderaSeleccionMenuArtefacto=0;
consejos();
flagSubsidio=3;
void clockDisplay() {
String currentTime = String(hour()) + ":" + minute();
Blynk.virtualWrite(V4, currentTime);
Blynk.virtualWrite(V5, currentDate);
EEPROM.begin(EEPROM_SIZE);
BlynkEdgent.begin();
SPI.begin();
radio.begin();
network.begin(90, this_node);
radio.setDataRate(RF24_2MBPS);
setSyncInterval(10 * 60); // Sync interval in seconds (10 minutes)
timer.setInterval(1000L, clockDisplay);
BlynkEdgent.run();
network.update();
