Before creating the topic
- Search forum for similar topics
- Check http://docs.blynk.cc and http://help.blynk.cc/
- Add details :
• Blynk Library version
• Add your sketch code. Code should be formatted as example below.
```/* Comment this out to disable prints and save space */
#include <WiFi.h>
#include <WiFiClient.h>
#include <Blynk.h>
char auth[] = "wVZ3-TfQ5xhKmUOlvXR3lf8HzHH3vBGB";
char ssid[] = "3c40a1";
char pass[] = "worry.863.gaze";
int sen1=15;
unsigned long t1=0;
float velocity;
pinMode(sen1,INPUT);
Serial.print(" Speed Detector ");
while(digitalRead(sen1));
while(digitalRead(sen1)==0);
t1=millis();
velocity=t1;
velocity=velocity/1000;//convert millisecond to second
velocity=(5.0/velocity);//v=d/t
velocity=velocity*3600;//multiply by seconds per hr
velocity=velocity/1000;//division by meters per Km
Serial.print(velocity);
Serial.print(" Miles/Hr ");
// to avoid delay() function!
