Sparkfun blynk board ESP8266 has blynk 2.0 support ?
I could make it become online but when i try to work with it the inputs are different from the board i only have esp8266 to choose when i create a template .
Its just hardware that is different (PCB pinout) but the base architecture is ESP8266. So Blynk 2.0 should work just fine.
Post your whole sketch properly formatted with (```) at the top and bottom of the sketch and also the schematic. And explain what you are trying to achieve.
i will try to configure it make some tests and check the sketch , I am planing to monitor my power and energy as we dont have full time grid energy i just to know and get notified when grid energy is on. i have 3 inputs grid electricity , private generator , and also i have solar , i have the sparkfun blynk board and 3 220 relay.
thanks a lot
First of all make sure the proper pinouts on your development board and you are using the same pins in code as well.
You will need to have proper hardware to detect power outages and consumption.
As you are dealing with high voltage, be sure of what you are doing.
Thanks a lot yes for sure i will make sure to choose the proper equipment , thanks again
