HI
sorry I saw that the forum has already talked about this, does anyone know when the time will be increased in the space for widgets?
I for example use Arduino Mega and I have many relays sensors etc. and the space on the app is not enough.
It has already planned a new release that solves the problem?
there is a forecast of its time to do this?
It plans to add new pages, or tab with the same token?
thank you all
sorry for my english
i use extra projects and the bridge function to tie them together to act as a cohesive system. So you could just add another Arduino uno (or whatever hardware board that you like using) and that will give you another dashboard. Then use virtual pins and the bridge function to make it work however you need.
I know this is a workaround for now and doesn’t actually answer your question. I do agree, it would be nice to be able to have multiple screens on one project.
thanks for your answer, and no one knows if this change is planned or in the “roadmap” … right?
thanks Dmitriy and congratulations for the excellent work
