Sound sensor with blynk
I need help with my project. I want to use a sound sensor with the blynk app with a gauge. ?
does anyone have a program ??
What kind of data are you getting without Blynk?
@Mhmfadhil please edit your post using the pencil icon at the bottom and add triple backticks at the beginning and end of your code so that it displays correctly.
In order to help you, we need more info. For example I noticed that you entered a 3 seconds delay if the input is high. During this time, what does esp8266 have to do? Must the microcontroller be insensitive to the input changes? Be careful because you have to avoid delays otherwise you would always lose the internet connection.
And yes, please, edit your code :pray:
DG
how to make a coding program, Monitor DB Sound Level with blynk
display (superchart) / (gauge)
if anyone understands I ask for help to make a coding program, please?? thank you
suara
@Mhmfadhil I’ve combined your new topic into the one that you created a few weeks ago then abandoned.
Please don’t keep creating new topics about the same subject or they will be deleted.
