Hello! I need some help with my project. I want to make a LED turn on or off using a sound sensor with a digital output and the blynk app using a button . I managed doing it separated but i actually want that when the sound sensor is transmiting 1 and the LED is on, the Blynk button to change into ON and if i press it to turn off the LED and change into off. Same if the LED is off.
So basically i want to control the LED with bouth sensor and app , app knowing all the time the LED state .
The Blynk button widget needs to be connected to a virtual pin.
You would do this with a Blynk.virtualWrite(Vx,0) command, to turn the switch widget off (0).
The state change of the button widget fires the BLYNK_WRITE(Vx) function. You would test if the switch is on (1) or off (0).
You’d then switch your physical LED on or off accordingly, using a digitalWrite command.
Take a look at some of the sketch builder examples:
or the Blynk docs:
https://docs.blynk.cc
for more details.
I did it ! I can’t belive i did it, i am so glad ! Thank you for the advice!
Here is the code, maybe someone is trying to do the same thing.
int soundSensor=7;
int LED=23;
boolean LEDStatus=false;
#include <ESP8266_Lib.h>
char auth[] = " ";
char ssid[] = " ";
char pass[] = " ";
#define EspSerial Serial1
//#include <SoftwareSerial.h>
// Your ESP8266 baud rate:
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
pinMode(soundSensor,INPUT);
pinMode(LED,OUTPUT);
// Set ESP8266 baud rate
BLYNK_WRITE(V0)
if(param.asInt()==HIGH)
digitalWrite(LED, HIGH);
digitalWrite(LED, LOW);
int SensorData=digitalRead(soundSensor);
Serial.println(SensorData);
if(SensorData==1)
if(LEDStatus==false)
LEDStatus=true;
digitalWrite(LED,HIGH);
Blynk.virtualWrite(V0,HIGH);
else if(LEDStatus==true)
LEDStatus=false;
digitalWrite(LED,LOW);
Blynk.virtualWrite(V0,LOW);
Well done on getting this far, but you should read this about how and why to move all of that code out of your void loop:
Another problem, if i turn the wi-fi off everything stop running. I would like the sound sensor part to be still functionaleven if the app is offline.
