[SOLVED] Working Email sketch for esp8266
Hello all, I am new to this. I am using an ESP8266 - 12e and it works great with the standalone, Now i want to get a working Emailer setup on one of them. The plan is to put a PIR in my garage, and every time someone is in there it will email me. are there working examples out there ?
thanks
Hello. You need simply call Blynk.email. Docs.
Thanks Dmitriy, I tried the following code. It gets an error when compiling "
exit status 1
‘emailOnButtonPress’ was not declared in this scope`
  • Blynk is a platform with iOS and Android apps to control
  • Arduino, Raspberry Pi and the likes over the Internet.
  • You can easily build graphic interfaces for all your
  • projects by simply dragging and dropping widgets.
  • Downloads, docs, tutorials: http://www.blynk.cc
  • Blynk community: http://community.blynk.cc
  • Social networks: http://www.fb.com/blynkapp
  •                           http://twitter.com/blynk_app
  • Blynk library is licensed under MIT license
  • This example code is in public domain.
  • This example runs directly on ESP8266 chip.
  • You need to install this for ESP8266 development:
  • https://github.com/esp8266/Arduino
  • Please be sure to select hte right ESP8266 module
  • in the Tools -> Board menu!
  • Change WiFi ssid, pass, and Blynk auth token to run :slight_smile:
char auth[] = “YourAuthToken”;
Blynk.begin(auth, “ssid”, “pass”);
// Wait until connected
// Send e-mail when your hardware gets connected to Blynk Server
// Just put the recepient’s “e-mail address”, “Subject” and the “message body”
Blynk.email("your_email@mail.com", “Subject”, “My Blynk project is online.”);
// Setting the button
pinMode(2, INPUT_PULLUP);
// Attach pin 2 interrupt to our handler
attachInterrupt(digitalPinToInterrupt(2), emailOnButtonPress, CHANGE);
void emailOnButtonPress()
// *** WARNING: You are limited to send ONLY ONE E-MAIL PER MINUTE! ***
// Let’s send an e-mail when you press the button
// connected to digital pin 2 on your Arduino
int isButtonPressed = !digitalRead(2); // Invert state, since button is “Active LOW”
if (isButtonPressed) // You can write any condition to trigger e-mail sending
BLYNK_LOG(“Button is pressed.”); // This can be seen in the Serial Monitor
Blynk.email("your_email@mail.com", “Subject: Button Logger”, “You just pushed the button…”);
You don’t need to use exactly this sketch. It is just example as you have ESP8266. Just add email command within your ESP code, that’s it.
@ryan_blynk with the very latest Arduino / ESP8266 the functions need to be in a SPECIFIC order so move void emailOnButtonPress() function before void setup(). It should then compile.
I did that, now it is telling me
Arduino: 1.6.7 (Windows 10), Board: “Generic ESP8266 Module, Serial, 80 MHz, 40MHz, DIO, 115200, 512K (64K SPIFFS), ck”
ESP8266_email_1:38: error: expected constructor, destructor, or type conversion before ‘(’ token
ESP8266_email_1:40: error: expected constructor, destructor, or type conversion before ‘(’ token
C:\Users\ryanm\Desktop\ESP8266_email_1\ESP8266_email_1.ino: In function ‘void emailOnButtonPress()’:
ESP8266_email_1:76: error: a function-definition is not allowed here before ‘{’ token
ESP8266_email_1:78: error: expected ‘}’ at end of input
exit status 1
“Show verbose output during compilation”
enabled in File > Preferences.
@ryan_blynk are your two include’s as shown below as they are invisible if you don’t format the sketch with the </> icon?
Think you messed up when you moved the function but without the sketch being formatted it is hard to tell. This is what you need, compiles fine.
//#define BLYNK_DEBUG
  // Let's send an e-mail when you press the button
  int isButtonPressed = !digitalRead(2); // Invert state, since button is "Active LOW"
    BLYNK_LOG("Button is pressed."); // This can be seen in the Serial Monitor
    Blynk.email("your_email@mail.com", "Subject: Button Logger", "You just pushed the button...");
  Blynk.begin(auth, "ssid", "pass");
  // Just put the recepient's "e-mail address", "Subject" and the "message body"
  Blynk.email("your_email@mail.com", "Subject", "My Blynk project is online.");
Thank you it works great now.
