Very, very, very occasionally when you select a device it appears not to recognise it. You can remove the device, refresh the token etc or switch to ESP8266 etc.
That takes me back to a booze cruise to Ostend.
Just for your information. As I understand them… The device choices in the App determine:
How the App maps device layout to our visual reference. Things like Digital and Analog Pins with designations (A, D, or GPIO) and numbering; If only using Virtual Pins, then you could probably use any device choice for any project…
And limits the “available” number of Vpins, probably due to “processing power” of a device… but that can be adjusted with a single define in the sketch -
#define BLYNK_USE_128_VPINS
You have to use Blynk Widget Digital D9 to control the onboard LED. Must be a mapping problem in the Blynk or Wemos drivers. Here’s what I’ve discerned by trial-and-error on my Wemos D1 mini:
Wemos pin Blynk Widget Button ESP8266 pin
D0 D2 16
D1 D3 5
D2 D4 4
D3 D8 0
D4 D9 2 (Built-in LED)
D5 D5 14
D6 D6 12
D7 D7 13
D8 D10 15
