[Solved] Wemos D1 mini + dht11 shield + example = Failed to read from DHT sensor!
Hi everybody. I’m running the example code for Wemos and dht11 from here http://examples.blynk.cc/ with a dht11 shield like on the photo. I tried with Wemos mini and standard and same issue:
[5263] Connected to WiFi
[5263] My IP: 192.168.0.29
[5263] Connecting to cloud.blynk.cc:8442
Photo of my connection:
Thank you very much
Here is the Code Extracted from page above:
#include <DHT.h>
char auth[] = “YourAuthToken”;
// Set password to “” for open networks.
char ssid[] = “YourNetworkName”;
char pass[] = “YourPassword”;
#define DHTPIN 2 // What digital pin we’re connected to
// Uncomment whatever type you’re using!
//#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
// This function sends Arduino’s up time every second to Virtual Pin (5).
// In the app, Widget’s reading frequency should be set to PUSH. This means
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
Serial.println(“Failed to read from DHT sensor!”);
return;
// Please don’t send more that 10 values per second.
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
//Blynk.begin(auth, ssid, pass, “blynk-cloud.com”, 8442);
dht.begin();
This is your bug. Pin 2 is NOT D2.
Look up the pinout on the WeMos site.
That’s right !!!. Thanks you very much !!!
similar problem is existing in node mcu.what may be the problem?
@Raju_Kumar are you confused over the ESP pinout like the OP?
I am also facing the same issue.
which pin numbering should i use ?
I want to connect it to D3
D3 is GPIO 0, you do not want to use that pin. it is a “special” pin that needs to be in a certain state at boot. ESP8266 Special Pins
I’d use D5 (gpio 4), D6 (gpio12) or D7 (gpio13)
same problem
#include <DHT.h>
char auth[] = "token";
char ssid[] = "ssid";
char pass[] = "pass";
#define DHTPIN 12          // What digital pin we're connected to
void sendSensor()
    return;
  dht.begin();
  timer.setInterval(5000L, sendSensor);
This DHT tester code working perfectly.
can anyone explain why DHT sketch for Blynk is not working??
// Example testing sketch for various DHT humidity/temperature sensors
// Written by ladyada, public domain
#include "DHT.h"
#define DHTPIN 0     // what digital pin we're connected to
//#define DHTTYPE DHT22   // DHT 22  (AM2302), AM2321
//#define DHTTYPE DHT21   // DHT 21 (AM2301)
// Connect pin 1 (on the left) of the sensor to +5V
// NOTE: If using a board with 3.3V logic like an Arduino Due connect pin 1
// to 3.3V instead of 5V!
// Connect pin 2 of the sensor to whatever your DHTPIN is
// Connect pin 4 (on the right) of the sensor to GROUND
// Connect a 10K resistor from pin 2 (data) to pin 1 (power) of the sensor
// Initialize DHT sensor.
// Note that older versions of this library took an optional third parameter to
// tweak the timings for faster processors.  This parameter is no longer needed
// as the current DHT reading algorithm adjusts itself to work on faster procs.
  Serial.println("DHTxx test!");
  dht.begin();
  // Wait a few seconds between measurements.
  delay(2000);
  // Reading temperature or humidity takes about 250 milliseconds!
  // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
  // Read temperature as Celsius (the default)
  // Read temperature as Fahrenheit (isFahrenheit = true)
  float f = dht.readTemperature(true);
  // Check if any reads failed and exit early (to try again).
  if (isnan(h) || isnan(t) || isnan(f)) {
    return;
  // Compute heat index in Fahrenheit (the default)
  float hif = dht.computeHeatIndex(f, h);
  // Compute heat index in Celsius (isFahreheit = false)
  float hic = dht.computeHeatIndex(t, h, false);
  Serial.print("Humidity: ");
  Serial.print(h);
  Serial.print(" %\t");
  Serial.print(t);
  Serial.print(" *C ");
  Serial.print(f);
  Serial.print(" *F\t");
  Serial.print("Heat index: ");
  Serial.print(hic);
  Serial.print(hif);
  Serial.println(" *F");
sorry, guys
it’s working perfectly.
void sendSensor()
    return;
   //Serial.println("Humidity: ");
  //Serial.println(h);
  //Serial.println(" %\t");
  //Serial.println("Temperature: ");
  //Serial.println(t);
there were no serial print statement for the temperature & humidity.
it print statments when error occurs.&often logs error statements.or problem may be due to lose contacts in wires.
Why? Especially on “poor little” ESP-01 there isn’t much to choose from. I’m using it as an output, and never had any issue. I think that as an INPUT, where it is pulled up by default (as it is the case with DHT’s) it will work just fine too.
I know what is the role of GPIO0 on ESP, but i don’t care about it during boot/flash stage. It never goes low on it’s own while booted (intentionally or not).
According to the chart in this post:
It oscillates then stabilises stabilises HIGH after around 100ms when the ESP is booted. So it could be LOW briefly during this time, but that won’t be an issue in most cases.
For someone who’s just wanting to connect a DHT11 and a couple of switches, and is a newcomer to working with ESPs, there’s are better pins to choose.
More advanced users can safely use almost all of the pins on an ESP, as we know what to look out for and how to choose appropriate pins for specific uses. But as a rule of thumb for newcomers it’s better to steer them away from the pins that may bite them in future.
Thanks @PeteKnight for digging it out. Nice work done by @wanek :slight_smile:
