@Lichtsignaal if you don’t allocate the numbers yourselves how would SimpleTimer know which timer to enable / disable / delete etc from a typical setup()?
Yes, you have to name them, but you don’t have to number them. SimpleTimer assigns them if you don’t. I never do it that way. I just do the timer1 = timer.setEtc
I think the timer1, timer3 etc. part is nothing more than an alias for a int. You declare them like “int timer1 = timer.setInterval” and so on.
Disable a timer with “timer.disable(timer1)”. Easier to read than numbers
I see what you mean but I think you are still missing a step.
As some timers are not defined in setup() the minimum requirement is that they are defined as a global variable. So to disable the timer you refer to it would be a minimum of:
int timer1; // without this you can’t disable it if it’s not in setup()
We simply allocate a number, in addition, to the variables name so we can keep a tally of how many we have.
int timer1 = 1;
Coders don’t always want to use timer1, timer2, timer3 etc. It might be buzzerTimer, LEDTimer, relayTimer and allocating the specific number to each means you can see just how many you have used.
I agree you need to declare your timers as int (or byte, for that matter, saves a couple bytes of memory ). You can do the whole setting up timers and declaring them int/byte in one go. SimpleTimer will assign the ID to it. I’m not quit sure for which occasion you would need the specific ID if you can reference to a timer with a readable name, but I agree, it may be splitting hairs and is probably a matter of preference of the coder
If you want ot use timer.disable() or timer.enable()… at all… then you must declare it global. Else it just wont work. In my example I chose not to include it… but I should have to help with understanding the compile error.
Costas is also correct. You can declare it global with a value, but the timer will replace it once you declare the same int a timer function.
If you take the PushData example, where it does not declare the timer to a var, then you will have no way to control it, and it will run forever (depending on setTimeout or setInterval)
I see what you mean, you have to declare it obviously, but what I meant was, you don’t have to declare them globally to use in functions. They can be scoped to the local function. They do need to exist before messing with them, in that way your example will not work, but if you declare it right before the if, it works fine (provided you do the “int timerNew = timer.set Etc”.
Notice that the functions that set timers return an int, which the function descriptions refer to as a “Timer ID”. This is a value that is unique to the individual timer and is meaningful to the SimpleTimer code, but not necessarily to the calling code or to the programmer. In fact, by reading the code, you can find out that a timer ID is just the array index of the timer that was allocated for you, BUT since that isn’t documented, good practice dictates that we do nothing with it other than store it to use for cancelling that same timer later on, if necessary. If you know you won’t be needing to do that, there isn’t even a reason to store it. A timer ID is the equivalent, but better! - of saying, “Hey, you know that timer I set three calls ago? The one that had an interval of 3000ms? Yeah, that one. I’m done with it. Please shut it off and return it to the pool of available timers.” Instead, you save the ID use it to explicitly specify which timer you meant.
You can store a timer ID anywhere, at any scope, that you can store an int, as long as it will still be in scope and undamaged, when & if you need to retrieve it.
it working perfectly in about 10 times. but after a few times control, unlockbutton not working, rs not change anymore.
(led display when i press button, after 2 secons led off and unlockbutton working)
Im also used timer.setinterval(1000L,senddata) in setup to get temperature data every second
Sounds like the 10 timers per instance issue. Increased to 16 with BlynkTimer instead of SimpleTimer but you will still have problems if the Timers are not being deleted correctly.
Will advise further when I know what library version you are using.
Thanks. Maybe u right, because 10 times is not exactly , i guess that, maybe 16 as u said. im using newest 0.4.8 but maybe the old library not delete correctly. So i will find and deleted old simpletimer.h and add the new ones right?
Yes ensure you have the correct libraries. You can remove the header file from your sketch now as it’s included in the main Blynk libraries. Conventionally we use BlynkTimer now but the Blynk guys have left SimpleTimer available for Blynkers that don’t update their libraries and code.
Just check and use blynktimer. The issue still have, not exactly how many times i used and it not working, it depend on real time, it about 30 minutes when turn it on.
Setup
I used timer.setinterval(1000L,sentdate)
Void sentdata()
To update data every second
Can help me this issue?!!
Sorry I will upload my code later…
@Trieu_Le now I have fixed your gruesome formatting, see how it was done with the 3 backticks by viewing your last post in edit mode (but then abandon without editing).
