[SOLVED] Unable to log in to Local Server Administration Website (Using IE)
Hi Blynk Team
:slight_smile:
I built a local Windows Blynk server and it seems that i cant logon to the local blynk Website i set the Certs and the certs are working.
the username is have is admin@blynk.cc and password admin
in the Log i set it to trace and this is the error i am getting
:sob:
07:42:43.698 INFO - Mqtt hardware server listening at 8440 port.
07:42:51.870 DEBUG- -Dio.netty.recycler.maxCapacityPerThread: 32768
07:42:51.870 DEBUG- -Dio.netty.recycler.maxSharedCapacityFactor: 2
07:42:51.870 DEBUG- -Dio.netty.recycler.linkCapacity: 16
07:42:51.870 DEBUG- -Dio.netty.recycler.ratio: 8
07:42:51.994 DEBUG- [id: 0x8f4afc1f, L:/127.0.0.1:9443 - R:/127.0.0.1:49286] HANDSHAKEN: TLS_RSA_WITH_AES_128_GCM_SHA256
07:42:51.994 DEBUG- [id: 0x50d2ac09, L:/127.0.0.1:9443 - R:/127.0.0.1:49284] HANDSHAKEN: TLS_RSA_WITH_AES_128_GCM_SHA256
07:42:51.994 DEBUG- [id: 0x00a2fd2e, L:/127.0.0.1:9443 - R:/127.0.0.1:49287] HANDSHAKEN: TLS_RSA_WITH_AES_128_GCM_SHA256
07:42:51.994 DEBUG- [id: 0x66bc5d36, L:/127.0.0.1:9443 - R:/127.0.0.1:49285] HANDSHAKEN: TLS_RSA_WITH_AES_128_GCM_SHA256
07:42:51.994 DEBUG- [id: 0x41185a4d, L:/127.0.0.1:9443 - R:/127.0.0.1:49283] HANDSHAKEN: TLS_RSA_WITH_AES_128_GCM_SHA256
07:42:52.018 DEBUG- [id: 0x9f6f6b92, L:/127.0.0.1:9443 - R:/127.0.0.1:49282] HANDSHAKEN: TLS_RSA_WITH_AES_128_GCM_SHA256
07:42:52.088 TRACE- Blynk server IOException.
java.nio.file.NoSuchFileException: C:\Users\Administrator\Desktop\Data\Blynk\static\fonts\ufonts.com_pfdindisplaypro-thin.woff
	at sun.nio.fs.WindowsException.translateToIOException(Unknown Source) ~[?:1.8.0_131]
	at sun.nio.fs.WindowsException.rethrowAsIOException(Unknown Source) ~[?:1.8.0_131]
	at sun.nio.fs.WindowsFileSystemProvider.isHidden(Unknown Source) ~[?:1.8.0_131]
	at java.nio.file.Files.isHidden(Unknown Source) ~[?:1.8.0_131]
	at cc.blynk.core.http.handlers.StaticFileHandler.serveStatic(StaticFileHandler.java:173) ~[server-0.25.3.jar:?]
	at cc.blynk.core.http.handlers.StaticFileHandler.channelRead(StaticFileHandler.java:129) ~[server-0.25.3.jar:?]
	at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:362) ~[server-0.25.3.jar:?]
	at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:348) ~[server-0.25.3.jar:?]
	at io.netty.channel.AbstractChannelHandlerContext.fireChannelRead(AbstractChannelHandlerContext.java:340) ~[server-0.25.3.jar:?]
	at io.netty.channel.ChannelInboundHandlerAdapter.channelRead(ChannelInboundHandlerAdapter.java:86) ~[server-0.25.3.jar:?]
	at cc.blynk.core.http.handlers.UrlReWriterHandler.channelRead(UrlReWriterHandler.java:31) ~[server-0.25.3.jar:?]
	at cc.blynk.core.http.handlers.CookieBasedUrlReWriterHandler.channelRead(CookieBasedUrlReWriterHandler.java:40) ~[server-0.25.3.jar:?]
	at cc.blynk.server.api.http.logic.business.AuthCookieHandler.channelRead(AuthCookieHandler.java:38) ~[server-0.25.3.jar:?]
	at cc.blynk.core.http.BaseHttpHandler.process(BaseHttpHandler.java:79) ~[server-0.25.3.jar:?]
	at cc.blynk.core.http.BaseHttpHandler.channelRead(BaseHttpHandler.java:56) ~[server-0.25.3.jar:?]
	at io.netty.handler.codec.MessageToMessageDecoder.channelRead(MessageToMessageDecoder.java:102) ~[server-0.25.3.jar:?]
	at io.netty.handler.codec.http.HttpServerKeepAliveHandler.channelRead(HttpServerKeepAliveHandler.java:64) ~[server-0.25.3.jar:?]
	at io.netty.channel.CombinedChannelDuplexHandler$DelegatingChannelHandlerContext.fireChannelRead(CombinedChannelDuplexHandler.java:438) ~[server-0.25.3.jar:?]
	at io.netty.handler.codec.ByteToMessageDecoder.fireChannelRead(ByteToMessageDecoder.java:310) ~[server-0.25.3.jar:?]
	at io.netty.handler.codec.ByteToMessageDecoder.channelRead(ByteToMessageDecoder.java:284) ~[server-0.25.3.jar:?]
	at io.netty.channel.CombinedChannelDuplexHandler.channelRead(CombinedChannelDuplexHandler.java:253) ~[server-0.25.3.jar:?]
	at io.netty.handler.ssl.SslHandler.unwrap(SslHandler.java:1273) ~[server-0.25.3.jar:?]
	at io.netty.handler.ssl.SslHandler.decode(SslHandler.java:1084) ~[server-0.25.3.jar:?]
	at io.netty.handler.codec.ByteToMessageDecoder.decodeRemovalReentryProtection(ByteToMessageDecoder.java:489) ~[server-0.25.3.jar:?]
	at io.netty.handler.codec.ByteToMessageDecoder.callDecode(ByteToMessageDecoder.java:428) ~[server-0.25.3.jar:?]
	at io.netty.handler.codec.ByteToMessageDecoder.channelRead(ByteToMessageDecoder.java:265) ~[server-0.25.3.jar:?]
	at io.netty.channel.DefaultChannelPipeline$HeadContext.channelRead(DefaultChannelPipeline.java:1334) ~[server-0.25.3.jar:?]
	at io.netty.channel.DefaultChannelPipeline.fireChannelRead(DefaultChannelPipeline.java:926) ~[server-0.25.3.jar:?]
	at io.netty.channel.nio.AbstractNioByteChannel$NioByteUnsafe.read(AbstractNioByteChannel.java:134) ~[server-0.25.3.jar:?]
	at io.netty.channel.nio.NioEventLoop.processSelectedKey(NioEventLoop.java:644) ~[server-0.25.3.jar:?]
	at io.netty.channel.nio.NioEventLoop.processSelectedKeysOptimized(NioEventLoop.java:579) ~[server-0.25.3.jar:?]
	at io.netty.channel.nio.NioEventLoop.processSelectedKeys(NioEventLoop.java:496) ~[server-0.25.3.jar:?]
	at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:458) ~[server-0.25.3.jar:?]
	at io.netty.util.concurrent.SingleThreadEventExecutor$5.run(SingleThreadEventExecutor.java:858) ~[server-0.25.3.jar:?]
	at io.netty.util.concurrent.DefaultThreadFactory$DefaultRunnableDecorator.run(DefaultThreadFactory.java:138) ~[server-0.25.3.jar:?]
	at java.lang.Thread.run(Unknown Source) [?:1.8.0_131]
07:42:59.650 TRACE- Blynk server IOException.
java.io.IOException: An existing connection was forcibly closed by the remote host
	at sun.nio.ch.SocketDispatcher.read0(Native Method) ~[?:1.8.0_131]
	at sun.nio.ch.SocketDispatcher.read(Unknown Source) ~[?:1.8.0_131]
	at sun.nio.ch.IOUtil.readIntoNativeBuffer(Unknown Source) ~[?:1.8.0_131]
	at sun.nio.ch.IOUtil.read(Unknown Source) ~[?:1.8.0_131]
	at sun.nio.ch.SocketChannelImpl.read(Unknown Source) ~[?:1.8.0_131]
	at io.netty.buffer.PooledUnsafeDirectByteBuf.setBytes(PooledUnsafeDirectByteBuf.java:288) ~[server-0.25.3.jar:?]
	at io.netty.buffer.AbstractByteBuf.writeBytes(AbstractByteBuf.java:1100) ~[server-0.25.3.jar:?]
	at io.netty.channel.socket.nio.NioSocketChannel.doReadBytes(NioSocketChannel.java:372) ~[server-0.25.3.jar:?]
	at io.netty.channel.nio.AbstractNioByteChannel$NioByteUnsafe.read(AbstractNioByteChannel.java:123) ~[server-0.25.3.jar:?]
07:42:59.665 DEBUG- POST : /admin/login
07:42:59.774 DEBUG- [id: 0x00baa9a9, L:/127.0.0.1:9443 - R:/127.0.0.1:49288] HANDSHAKEN: TLS_RSA_WITH_AES_128_GCM_SHA256
07:42:59.790 TRACE- Blynk server IOException.
07:43:05.070 TRACE- Blynk server IOException.
07:43:05.148 TRACE- Blynk server IOException.
Thanks for reporting. I’ll check.
Hi Dmitriy
i installed Chrome now and it seems to resolved the issue, the issues seems to be with IE
Thanks for helping out
Juan
IE is fairly old… do you meen Edge?
Hi Gunner
:slight_smile:
No i mean that when i try to open Blynk on my local server i can only use Google Chrome, Internet Explorer is not working for the administration side
Thanks for all your guys great work :trophy:
I think I will always refer to Microsoft’s browser as IE :slight_smile:
I’ll check this issue today. Probably problem on our side.
Yah, IE or (Dull) Edge… either way it is referred to, I ignore it and use Chrome all the way :slight_smile:
I only use IE for testing or when I have cache / DNS propagation issues etc.
@Juanb do you have file C:\Users\Administrator\Desktop\Data\Blynk\static\fonts\ufonts.com_pfdindisplaypro-thin.woff in your system?
Hi
Yes this is my location where Blynk is running i noticed that the Fonts is not there
Ok. The issue is fixed. I made the release with fix - https://github.com/blynkkk/blynk-server/releases/tag/v0.25.4
Please check it and let me know in case you have any other issues.
Thanks guys (great Application keep it going)
