So, you have setup your own local server, but only using direct pin manipulation? Kind of like having a race car on a private track… but just sitting in the pits flicking the lights on and off
As with your other topic re: the History graph… while I do see the provision for entering Digital and Analog pins, they don’t seem to function without code. I now always use virtual pins as I prefer to drive my race car
@Dmitriy @vshymanskyy In certain widgets like the Timer and History Graph, are these direct pin options truly available without code?.. If so, then they don’t seem to work, at least in this OP (and my own tests - granted, mixed in with an existing project that otherwise uses vpins). If not, then those pin options should perhaps be removed so as not to confuse new users.
