[Solved] SimpleTimer not working no more?
Social networks:            http://www.fb.com/blynkapp
                            http://twitter.com/blynk_app
  NOTE:    It is recommended to use SparkCorePolledTimer library
       to make periodic actions (similar to SimpleTimer on Arduino).
  Blynk using a LED widget on your phone!
  App project setup:
LED widget on V1
  WARNING :
  For this example you'll need SimpleTimer library:
https://github.com/jfturcot/SimpleTimer
  Visit this page for more information:
http://playground.arduino.cc/Code/SimpleTimer
#include "blynk/blynk.h"
char auth[] = "xxxxxxxx";
WidgetLED led1(V1);
// V1 LED Widget is blinking
void blinkLedWidget()
  if (led1.getValue()) {
led1.off();
Serial.println("LED on V1: off");
led1.on();
Serial.println("LED on V1: on");
  delay(5000); // Allow board to settle
  Blynk.begin(auth);
Found this code on the Blynk Example. I am trying to run this on the Particle Photon.
/src/tester_timer.cpp:40:25: fatal error: SimpleTimer.h: No such file or directory
 void loop();
compilation terminated.
make[1]: *** [../build/target/user/platform-6src/tester_timer.o] Error 1
make: *** [user] Error 2
Spark products have their own timer, SparkCorePolledTimer.
Search this site for SparkCorePolledTimer.
Try to install the SimpleTimer library again from https://github.com/jfturcot/SimpleTimer
Old topic, and already solved.
@Amjed_Saood This is a very old topic… please check the date stamps before posting. As for the issue, and as already answered, the OP uses a device that requires a specialised timer made for that device.
