Hi folks!
I am trying to set Virtual pin 3 high with the following line:
Blynk.virtualWrite(V3, HIGH);
The led widget does not light when I connect it to Virtual pin 3. Am I missing a trick here?
Thanks in advance.
Hi folks!
Thanks in advance.
Have you tried using 1 instead of HIGH? I think both should work though.
Hello. Yes. Please have a look into documentation.
Either use LedWidget.on() either send 255, not 1.
Thanks guys! replacing the HIGH with 255 works, your help is much appreciated!
