Ok that confirms you are using a valid token.
You might have some ports blocked.
Try the following from dos command / console to see if it connects for a short duration before disconnecting you
telnet blynk-cloud.com 8443
Edit: You should concentrate on the regular USB sketch not the SoftwareSerial one.
