[SOLVED] RTC Time Sync - setSyncInterval
Hi all,
I have a problem with RTC.
The first time I try to get time I get back year-> 1970
Thx,
Andreas
Here is my code:
#include "SimpleTimer.h"
#include <Ethernet.h>
#include <TimeLib.h>
#include <WidgetRTC.h>
const char* auth     = "0fd--------a-d4";
const char* ssid     = "xxx";
const char* password = "xxxx";  //del
WidgetLED       GarageLed(V6);
WidgetRTC       rtc;
WidgetTerminal  BlynkTerminal(V2);
boolean         AlarmState = false;
boolean         NightMode;
int             AlarmTimerId;
int             PIRState = false;
unsigned long   LastAlarmMillis;
SimpleTimer     AlarmTimerOff;
SimpleTimer     Timer1;
bool isFirstConnect = true;
BLYNK_ATTACH_WIDGET(rtc, V5);
BLYNK_CONNECTED()
  if (isFirstConnect)
    Blynk.syncAll();
    isFirstConnect = false;
void clockDisplay()
  Serial.println (TimeS());
String lpad(String txt, byte width, String pattern) {
  String tmp = txt;
  for (byte i=tmp.length(); i<width; i++)
    tmp = pattern + tmp;
  return tmp;
String TimeS()
  String currentTime = lpad(String(hour()), 2, "0") + ":" + lpad(String(minute()), 2, "0") + ":" + lpad(String(second()), 2, "0");
  String currentDate = String(day()) + "/" + month() + "/" + year();
  return (currentDate + " " + currentTime);
  Timer1.setInterval(3000, clockDisplay);
  Blynk.begin(auth, ssid, password);
  while (Blynk.connect() == false) {}
  Serial.println("Connected To Blynk");
  rtc.begin();
  Timer1.run();
And the output I get:
[3247] Connected to WiFi
[3247] IP: 192.169.200.162
[3247] Blynk v0.3.7 on ESP8266
[5001] Connecting to blynk-cloud.com:8442
[5182] Ready (ping: 1ms).
Connected To Blynk
1/1/1970 00:00:05
[5375] Time sync: OK
13/6/2016 09:30:21
13/6/2016 09:30:24
13/6/2016 09:30:27
13/6/2016 09:30:30
13/6/2016 09:30:33
13/6/2016 09:30:36
I think the problem is in Blynk.syncAll();
BLYNK_CONNECTED()
  if (isFirstConnect)
    Blynk.syncAll();
Inside syncAll() probably the virtual pins are synced before time sync. So if you try to get a timestime, you will not get it.
As a result of that when we have the following is automatically executed (because of SyncAll) it does not have the time synced yet.
BLYNK_WRITE(V4)
  if (param.asInt()==1)
    NightMode = false;
    .... print timestamp
    NightMode = true;
I dont know if I am right but what I suggest is that inside SyncAll, timesync must be executed before the BLYNK_WRITE
Andreas
You probably right. You may skip wrong date with simple condition. like if year == 1970
thx Dimitry
As it is an alarm logging, δate is needed from the first hit. For the time being I did exclude 1970 dates.
I do think though that there is a problem with RTC sync.
Check the following.
Time Sync is not done in the first minutes. It is done only after a big idle time ( [461822] Time sync: OK
[3249] Connected to WiFi
[3249] IP: 192.169.200.162
[3249] Blynk v0.3.7 on ESP8266
[5188] Ready (ping: 1ms).
Syncing ......AK..
## No Time ??       [Garage] Booted
## No Time ??       [Garage] Day Mode
## No Time ??       [Garage] ALARM On
## No Time ??       [Garage] ALARM Off
13/06/2016 14:16:39 [Garage] ALARM Off
13/06/2016 14:38:46 [Garage] ALARM On
[1791385] Time sync: OK
13/06/2016 14:38:48 [Garage] ALARM Off
@vshymanskyy any suggestions?
Yes.
TimeSync must be better handled.
It is not clear for me and maybe for others when the timesync occures.
I would really like an answer on that.
I believe one solution would be to include time sync in the syncall function or to sync with a separate command.
thx
Andreas
The same proble is described here
LINK
and here
LINK2
Guys PLEASE !
RTC is a great and important feature that does not work well.
Time sync happens in random times…
please :slight_smile:
Andreas
I don’t think it is random, I believe the default is to sync every 5 minutes and you can change the sync interval.
Costa please give more details:
  1. How to force time sync on startup (setup() function)
  2. How do we change the sync interval.
Thx
Andreas
http://www.pjrc.com/teensy/td_libs_Time.html as used by Blynk’s RTC widget at https://github.com/blynkkk/blynk-library/blob/b976c1f1522a30899e261cf0538ee66937b43a5d/examples/Widgets/RTC/RTC.ino makes use of setSyncInterval(seconds)
So in setup() maybe something like:
  setSyncInterval(1);
  rtc.begin();
  Blynk.syncAll();
Also do the == 1970 check.
Costas you are a GOD!
This works perfectly…
  setSyncInterval(1);
  rtc.begin();
  setSyncInterval(900000);  //every 15min
