Hello Blynkers,
I have difficulties to reset interval of timers using timer.deleteTimer function. It is partially linked with the this topic
I want to achieve something similar.
Complete code below, involved section is “BRUMISATION”
//**********DEFINE**********//
#define D0 16
#define D1 5
#define D2 4
#define D3 0
#define D4 2
#define D5 14
#define D6 12
#define D7 13
#define D8 15
//**********LIB**********//
#include <Wire.h>
#include <Adafruit_BME280.h>
#include <Adafruit_Sensor.h>
#include <TimeLib.h>
Adafruit_BME280 bme; // I2C
//**********TOKEN (OK)**********//
char auth[] = "";
//**********WIFI (OK)**********//
char ssid[] = "xx";
char pass[] = "xx";
//**********HEAT BUTTON PIN**********//
const int heatrelayPin = D3;
void HeatButton();
int heatrelayState = HIGH;
//**********WATER BUTTON PIN**********//
const int waterrelayPin = D7;
void WaterButton();
int waterrelayState = HIGH;
//**********LIGHT BUTTON PIN**********//
const int lightrelayPin = D6;
void LightButton();
int lightrelayState = HIGH;
BLYNK_CONNECTED() {
Blynk.syncAll();
//**********BME TO BLYNK (OK)**********//
void sendSensor()
float h = bme.readHumidity();
float t = bme.readTemperature();
if (isnan(h) || isnan(t)) {
Serial.println("Failed to read from BME sensor!");
return;
Blynk.virtualWrite(V18, h);
Blynk.virtualWrite(V17, t);
//**********BUTTONS**********//
BLYNK_WRITE(V20) {
heatrelayState = param.asInt();
digitalWrite( heatrelayPin,heatrelayState );
BLYNK_WRITE(V22) {
waterrelayState = param.asInt();
digitalWrite( waterrelayPin,waterrelayState );
BLYNK_WRITE(V24) {
lightrelayState = param.asInt();
digitalWrite( lightrelayPin,lightrelayState );
//*********BRUMISATION***********//
int freq;
void brumistart(){
Blynk.virtualWrite(V22,0);
//digitalWrite( waterrelayPin,waterrelayState );
void brumistop(){
Blynk.virtualWrite(V22,1);
BLYNK_WRITE(V0){
int freq = param.asInt();
int timerV0START1;
int timerV0START2;
int timerV0STOP1;
int timerV0STOP2;
if (freq != 0) {
timer.deleteTimer(timerV0START1);
timer.deleteTimer(timerV0STOP1);
timer.deleteTimer(timerV0START2);
timer.deleteTimer(timerV0STOP2);
timerV0START1 = timer.setInterval(freq*60000L, brumistart);
timerV0STOP1 = timer.setInterval(freq*60000L+4000L, brumistop);
timerV0START2 = timer.setInterval(freq*60000L+4000L+6000L, brumistart);
timerV0STOP2 = timer.setInterval(freq*60000L+4000L+6000L+4000L, brumistop);
//**********DEBUG CONSOLE**********//
//**********ESP SETUP (OK)**********//
delay(200);
//**********BME SENSOR (OK)**********//
bme.begin();
delay(100);
//**********SWITCH HEAT ON/OFF**********//
pinMode(heatrelayPin, OUTPUT);
//**********SWITCH WATER ON/OFF**********//
pinMode(waterrelayPin, OUTPUT);
//**********SWITCH LIGHT ON/OFF**********//
pinMode(lightrelayPin, OUTPUT);
V0 is a numeric input or a step button (I tried both), It works well the first time I trigger V0, but after, the interval stays the same. It looks like the interval is not deleted and recreated like it should (or like I want
Any ideas why ?
