I am currently encountering a problem with (I assume) the time.h library and the time input setting controller. The value of my variable used to count the time from 1970 do not send me back the right time. I guess the problem comes from the “hour()” and others functions that don’t send me back the right value of time. It seems to contain the time from the begining of the uploaded sketch.
Usualy when the esp8266 nodeMCU is ready, this value contains around 40 to 60 secondes.
My code is based on several codes find in this forum where all log supplied seem correct so I don’t get what is my problem.
I am using an Esp8266 NodeMCU (http://www.cnx-software.com/wp-content/uploads/2015/10/NodeMCU_v0.9_Pinout.png).
Concerning my config, I have the lastest release of the blynk library (0.4.0) and the latest arduino software (1.6.12). I have tried the 1.6.5 and the 1.6.10 and I encounter the same problem.
All libraries used on sketch supplied on this forum are present in my sketch (probably too much). All libraries are installed on my computer.
I have tried to change some values and to modify my program but nothing changed. I have not seen on the internet any incompatibility problems and even if it has been some issues, my two others tries with older version of arduino software would solve my issue.
I already run some basic sketch permitting to blink a led and it worked well with the blynk app (Android). I don’t find anything on the web to fix my problem.
You can find in attachment my sketch and some logs of my problem. I have make my code much more simpler and the problem is still the same.
Do you have any idea to correct this ? I hope some of you will be able to help me.
By the way, I discovered blynk 3 days ago and the interface is really easy to manage and to use.
Thank you for your work and for your answer.
— LOGS
[26641] Connecting to blynk-cloud.com:8442
[26761] Ready (ping: 1ms).
Checked schedule at: 00:00:41
01/01/1970
Weekday 5
dayadjustment -1
valeur t.isWeekdaySelected((weekday() + dayadjustment)): 1
---- Inside t.isWeekdaySelected((weekday() + dayadjustment)) ---- nowseconds :
41
startseconds :
32700
Time zone: Europe/Paris
Time zone offset: 3600
Checked schedule at: 00:00:52
01/01/1970
Weekday 5
dayadjustment -1
52
startseconds :
32700
— LOGS
==> As you can see the nowsecond value is 41 or 52. I am not expecting that.
– code
define BLYNK_PRINT Serial // Comment this out to disable prints and save space
include <ESP8266WiFi.h>
include <BlynkSimpleEsp8266.h>
include <WiFiUDP.h>
include <Time.h>
include <TimeLib.h>
include <SimpleTimer.h>
include <WidgetTimeInput.h>
//Blynk
char auth[] = "";
char ssid[] = "";
char pass[] = "";
char Date[16];
char Time[16];
long startseconds; // start time in seconds
long stopseconds; // stop time in seconds
long nowseconds; // time now in seconds
int pinD = 12; // GPIO12 D6
int pinQ = 04; // GPIO4 D2
int valueD = LOW;
int valueQ = LOW;
//fin tempo
WiFiServer server(80);
while (Blynk.connect() == false)
// Wait until connected
timer.setInterval(60000L, activetoday); // check every minute if schedule should run today
timer.setInterval(30000L, reconnectBlynk); // check every 30s if still connected to server
// Initialisation
pinMode(pinD, OUTPUT); // MOCP
pinMode(pinQ, OUTPUT); // MOCN
// Défault value
digitalWrite(pinD, LOW);
digitalWrite(pinQ, LOW);
} // end SETUP
if (Blynk.connected())
} // end loop
// Functions
// BLYNK Time Input
// Time input widget allows you to select start/stop time, day of week, timezone, sunrise/sunset formatted values and send them to your hardware
BLYNK_WRITE(V1) {
sprintf(Date, "%02d/%02d/%04d", day(), month(), year());
TimeInputParam t(param);
Serial.print("Checked schedule at: ");
Serial.println(Time);
Serial.println(" ");Serial.println(Date);
int dayadjustment = -1;
// debug
Serial.print("Weekday ");
Serial.println(weekday());
Serial.print("dayadjustment ");
Serial.println(dayadjustment);
Serial.print("valeur t.isWeekdaySelected((weekday() + dayadjustment)): ");
Serial.println(t.isWeekdaySelected((weekday() + dayadjustment)));
// debug
if (weekday() == 1)
dayadjustment = 6; // needed for Sunday, Time library is day 1 and Blynk is day 7
// Monday to friday
if (t.isWeekdaySelected((weekday() + dayadjustment))>0) //Time library starts week on Sunday, Blynk on Monday
Serial.print(" ---- Inside t.isWeekdaySelected((weekday() + dayadjustment)) ---- ");
// current time
nowseconds = ((hour() * 3600) + (minute() * 60) + second());
// start time
startseconds = (t.getStartHour() * 3600) + (t.getStartMinute() * 60);
Serial.println("nowseconds : ");
Serial.println(nowseconds);
Serial.println("startseconds : ");
Serial.println(startseconds);
if (nowseconds >= startseconds)
digitalWrite(pinD, HIGH);
if (nowseconds <= startseconds)
// stop time
stopseconds = (t.getStopHour() * 3600) + (t.getStopMinute() * 60);
if (nowseconds >= stopseconds)
} //end monday-friday
// Fait rien
// Process timezone
// Timezone is already added to start/stop time
Serial.println(String("Time zone: ") + t.getTZ());
// Get timezone offset (in seconds)
Serial.println(String("Time zone offset: ") + t.getTZ_Offset());
void activetoday() { // check if schedule should run today
if (year() != 1970) {
Blynk.syncVirtual(V1); // sync timeinput widget
sprintf(Date, "%02d/%02d/%04d", day(), month(), year()); // COSTAS
sprintf(Time, "%02d:%02d:%02d", hour(), minute(), second()); // COSTAS
void reconnectBlynk()
if (!Blynk.connected())
if (Blynk.connect())
BLYNK_LOG("Reconnected");
BLYNK_LOG("Not reconnected");
