where is the #include <SoftwareSerial.h> ?
i have some Problem IDE Say: ERROR Compilling for Board …
i think Caused Do not find The SoftwareSerial.h’s file
So How can i do Arduino with ESP 01.
I flashed The Esp 01 With “AT22SDK10020150320boot12.bin” So Which Sketchs Are For Arduino Serial Communication With ESP 01 ?
Which boards are you using? Do you have an arduino uno AND a ESP01 for wifi connection? or do you just have an ESP01?
So are you using an arduino mega? or an arduino uno? How many physical microcontrollers are sitting in front of you:
Uno , Nano , Mega
i just click on compile for test sketch but …
[14646] Failed to enable MUX
[15657] Failed to set STA mode
Sounds like you do not have all the proper Arduino libraries installed, or installed incorrectly.
Reinstall the latest Arduino IDE and make sure you add in the ESP8266 board support.
Please copy/paste your code (formatted properly as required) instead of just screen shots. Thank you.
I have no idea what you are trying to say ![]()
@Gunner i success to use arduino with esp 01 but on app side the device connect and disconnect again connect and disconnect. why?on serial monitor i have:
[9]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v0.4.8 on Arduino Nano
[592] Connecting to **************
[13628] AT wersion:1.2/0.0(Jul 1 3016 20:04:44)
SDK vershon:1.5.4.1(39cn
[14678] Failed to set STA mode
[34892] Ready (ping: 11ms).
[44914] Login timeout
[201092] Ready (ping: 14ms).
[211115] Login timeout
[257491] Ready (ping: 18ms).
[267513] Login timeout
[282618] Ready (ping: 11ms).
[292640] Login timeout
You are using SoftwareSerial for your ESP connection, so drop the BAUD rate in both the sketch and on your ESP to 9600.
And as stated before, please copy paste your sketches next time… too hard to read screenshots
you said that i use a same baudrate for both esp and arduino serial? like this:
http://twitter.com/blynk_app
WARNING!
It's very tricky to get it working. Please read this article:
http://help.blynk.cc/hardware-and-libraries/arduino/esp8266-with-at-firmware
You’ll need:
- Blynk App (download from AppStore or Google Play)
- Arduino Uno board
example.
#include <ESP8266_Lib.h>
char auth[] = "*********************************";
char ssid[] = "******************";
char pass[] = "*****************";
//#define EspSerial Serial
// Your ESP8266 baud rate:
#define ESP8266_BAUD 115200
ESP8266 wifi(&EspSerial);
// Set ESP8266 baud rate
//Blynk.begin(auth, wifi, ssid, pass);
//Blynk.begin(auth, wifi, ssid, pass, "192.168.1.6", 8442);
Blynk.begin(auth, wifi, ssid, pass, IPAddress(192,168,1,6), 8442);
// to avoid delay() function!
and another problem is when i use local server setring uncomment in this example:
said
'IPAddress' was not declared in this scope
No, I said you need to set the BAUD rate of 9600 in BOTH the ESP (via AT commands) and in your sketch: #define ESP8266_BAUD 9600
I don’t know why it is shown this way in the examples??
This is what works for me:
Blynk.begin(auth, wifi, ssid, pass, "10.10.3.13", 8442);
NOTE: The quotes and the use of periods instead of commas… might work with commas? but I haven’t bothered to test as this works just fine.
ok but it cofigured to " 115200 " as default firmware you mean i decrease it on both side ESP(Firmware) and Sketch(ESP_BAUDRATE) ?
so what is wrong with 115200?
i use this method but problem is IPAddress i ask about IPAddress.
Thank You.
I don’t know… I see the Failed to enable MUX on mine as well (ESP-01 & MEGA) but it doesn’t seem to affect anything.
error
