Hi!,
i’ve successfully created a local server for storing data received from a Particle Photon Device on my PC, but i am having some problems with the configuration of my Photon device. It connects to the network via WiFI, and the local server is connected via Ethernet. I see on the log file from the local server the connections from the visualizaton app on my phone, but i don’t see any data value on the graph, not on the /data subdirectory of local server. The code running on the Particle Photon is the following. Any idea about the problem i’m having? could any expert which successfully connected a photon device to Blynk by using a local server share a reference code?. thanks
#include <blynk.h>
// El timer debe impleentarseiene que ser con esta librería
#include <SparkCorePolledTimer.h>
#define BLYNK_DEBUG
SparkCorePolledTimer myTimer(20000); //Create a timer object and set it's timeout in milliseconds
delay(5000);
Blynk.begin(auth, IPAddress(xx,xx,xx,xx); // ommited
myTimer.SetCallback(sendUptime);
void sendUptime()
Blynk.run(); // all the Blynk magic happens here
myTimer.Update();
