Hi All,
I am trying to set up my local server and managed to go through everything so far.
when logging in with the default admin@blynk.cc account the auth codes were sent out just fine. (without any configuration form my end).
Once I registered a new account and wanted to send out the Auth code for a project I got an error message telling me “Notification Error. Try again later.”
I deleted the account, and created an account using the same email address that I also configured in the Server Config to be the sender email address. (gmail.com, using the default port 587, lowered the security in the gmail settings so it should be all right)
I am using the latest version 2.18.0(1) iOS app and the server-0.35.3-java8.jar version on the Raspberry pi as the server.
If anyone encountered the same issue and managed to solve it, I would appreciate any help
Thank you
