I am using the NodeMCU V2 ESP8266 module as the main controller of my room automation project.
As a result, I’m relying on this module run consistently 24/7. It works very well up until it reaches “Cmd Error” and begins looping “Connecting to blynk-cloud.com:8442”. Here is my code and the interesting part of the Serial debug output.
#define BLYNK_DEBUG
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h>
//Network Info
const char* ssid = "ssid";
const char* password = "password";
//Blynk
char auth[] = "auth";
// Hue constants
const char hueHubIP[] = "hubIP"; // Hue hub IP
const char hueUsername[] = "username"; // Hue username
const int hueHubPort = 80;
// Hue variables
String command;
ESP8266WebServer server(80);
String webPage = "";
boolean nextRoomLightState = 0;
boolean currentRoomLightState = 0;
boolean nextLEDState = 0;
boolean currentLEDState = 0;
boolean nextLampState = 0;
boolean currentLampState = 0;
int currDimValue = 0;
int prevDimValue = 0;
boolean sleepButton = false;
const long interval = 500;
BLYNK_WRITE(V0){
nextRoomLightState = param.asInt(); // assigning incoming value from pin V0 to a variable
BLYNK_WRITE(V1){
nextLEDState = param.asInt(); // assigning incoming value from pin V1 to a variable
BLYNK_WRITE(V3){
nextLampState = param.asInt(); // assigning incoming value from pin V3 to a variable
BLYNK_WRITE(V4){
currDimValue = param.asInt(); // assigning incoming value from pin V4 to a variable
BLYNK_WRITE(V5){
sleepButton = param.asInt(); // assigning incoming value from pin V4 to a variable
void handleRoot() {
void handleNotFound(){
String message = "File Not Found\n\n";
message += "URI: ";
message += server.uri();
message += "\nMethod: ";
message += (server.method() == HTTP_GET)?"GET":"POST";
message += "\nArguments: ";
message += server.args();
message += "\n";
for (uint8_t i=0; i<server.args(); i++){
message += " " + server.argName(i) + ": " + server.arg(i) + "\n";
server.send(404, "text/plain", message);
void setup(void){
//Blynk
Blynk.begin(auth, ssid, password);
pinMode(V0, INPUT); //room lights
pinMode(V1, INPUT); //LEDs
pinMode(V3, INPUT); //lamp
pinMode(V4, INPUT); //dim
pinMode(D2, OUTPUT);
pinMode(1, OUTPUT);
digitalWrite(1, LOW);
WiFi.begin(ssid, password);
Serial.println("");
//Root Webpage HTML
webPage += "<a href=\"LEDon\"><button>LED On</button></a><br>";
webPage += "<a href=\"LEDoff\"><button>LED Off</button></a><br>";
webPage += "<a href=\"lamp_on\"><button>Lamp On</button></a><br>";
webPage += "<a href=\"lamp_off\"><button>Lamp Off</button></a><br>";
webPage += "<a href=\"room_light_on\"><button>Room Light On</button></a><br>";
webPage += "<a href=\"room_light_off\"><button>Room Light Off</button></a><br>";
Serial.println("");
Serial.print("Connected to ");
Serial.println(ssid);
Serial.print("IP address: ");
if (MDNS.begin("esp8266")) {
Serial.println("MDNS responder started");
//Root Site
server.on("/", [](){
server.send(200, "text/html", webPage);
server.on("/LEDon", [](){
server.sendHeader("Location", String("/"), true);
server.send ( 302, "text/plain", "");
nextLEDState = 1;
LEDon();
server.on("/LEDoff", [](){
nextLEDState = 0;
LEDoff();
server.on("/lamp_on", [](){
nextLampState = 1;
lamp_on();
server.on("/lamp_off", [](){
nextLampState = 0;
lamp_off();
server.on("/room_light_on", [](){
nextRoomLightState = 1;
roomLightOn();
server.on("/room_light_off", [](){
roomLightOff();
server.onNotFound(handleNotFound);
server.begin();
Serial.println("HTTP server started");
void loop(void){
server.handleClient();
updateAllSystems();
void updateAllSystems(){
unsigned long currentMillis = millis();
if(currentMillis - previousMillis >= interval){
updateRoomLights();
updateLED();
updateLamp();
updateDim();
sleepMode();
void sleepMode(){
if(sleepButton == true){
nextLampState = 0;
nextLEDState = 0;
roomLightOff();
lamp_off();
LEDoff();
void updateDim(){
if(currDimValue != prevDimValue){
command = "{\"bri\":" + String(currDimValue) + "}";
setHue(1,command);
setHue(2,command);
Serial.println(currDimValue);
prevDimValue = currDimValue;
void updateLamp(){
//if light should be on, turn on light
if(nextLampState == 1 && currentLampState == 0){
lamp_on();
}//if light should be off, turn off light
else if(nextLampState == 0 & currentLampState == 1){
lamp_off();
//Virtual Pin V3 == lamp
void lamp_on(){
Serial.println("lamp_on");
currentLampState = 1;
HTTP_GET_REQ("10.0.0.250", "/lightOn");
Blynk.virtualWrite(3, 1);
Blynk.syncVirtual(3);
void lamp_off(){
Serial.println("lamp_off");
HTTP_GET_REQ("10.0.0.250", "/lightOff");
Blynk.virtualWrite(3, 0);
void updateLED(){
if(nextLEDState == 1 && currentLEDState == 0){
LEDon();
else if(nextLEDState == 0 & currentLEDState == 1){
LEDoff();
//Virtual Pin V1 == LED
void LEDon(){
Serial.println("LEDon");
digitalWrite(D2, HIGH);
currentLEDState = 1;
Blynk.virtualWrite(1, 1);
Blynk.syncVirtual(1);
void LEDoff(){
Serial.println("LEDoff");
digitalWrite(D2, LOW);
Blynk.virtualWrite(1, 0);
void updateRoomLights(){
if(nextRoomLightState == 1 && currentRoomLightState == 0){
roomLightOn();
else if(nextRoomLightState == 0 & currentRoomLightState == 1){
roomLightOff();
void roomLightOn(){
Serial.println("roomLightOn");
command = "{\"on\":true, \"bri\":" + String(currDimValue) + "}";
setHue(1,command);
delay(5);
setHue(2,command);
currentRoomLightState = 1;
Blynk.virtualWrite(0, 1);
Blynk.syncVirtual(0);
void roomLightOff(){
Serial.println("roomLightOff");
command = "{\"on\": false}";
setHue(1,command);
delay(5);
setHue(2,command);
Blynk.virtualWrite(0, 0);
void HTTP_GET_REQ(char* host, char* url){
// Use WiFiClient class to create TCP connections
WiFiClient client;
const int httpPort = 80;
if (!client.connect(host, httpPort)) {
return;
Serial.print("Requesting URL: ");
Serial.println(url);
//This will send the request to the server
client.print(String("GET ") + url + " HTTP/1.1\r\n" +
"Host: " + host + "\r\n" +
"Connection: close\r\n\r\n");
unsigned long timeout = millis();
while (client.available() == 0) {
if (millis() - timeout > 5000) {
Serial.println(">>> Client Timeout !");
client.stop();
return;
/* setHue() is our main command function, which needs to be passed a light number and a
* properly formatted command string in JSON format (basically a Javascript style array of variables
* and values. It then makes a simple HTTP PUT request to the Bridge at the IP specified at the start.
boolean setHue(int lightNum, String command)
Serial.print("setHue: ");
Serial.println(String(lightNum));
WiFiClient client;
if (client.connect(hueHubIP, hueHubPort))
client.print("PUT /api/");
client.print(hueUsername);
client.print("/lights/");
client.print(lightNum); // hueLight zero based, add 1
client.println("/state HTTP/1.1");
client.println("keep-alive");
client.print("Host: ");
client.println(hueHubIP);
client.print("Content-Length: ");
client.println(command.length());
client.println("Content-Type: text/plain;charset=UTF-8");
client.println(); // blank line before body
client.println(command); // Hue command
client.stop();
return true; // command executed
return false; // command failed
Serial Output:
lamp_on
Requesting URL: /lightOn
[2548382] <[14|01|11|00|06]vw[00]3[00]1
[2548505] <[10|01|12|00|04]vr[00]3
[2548591] >[14|01|12|00|06]
[2548591] >vw[00]3[00]1
[2549553] >[14]R[0A|00|06]
[2549553] >vw[00]3[00]0
lamp_off
Requesting URL: /lightOff
[2549972] <[14|01|13|00|06]vw[00]3[00]0
[2550105] <[10|01|14|00|04]vr[00]3
[2550202] >[14|01|14|00|06]
[2550203] >vw[00]3[00]0
[2560200] <[06|01|15|00|00]
[2560319] >[00|01|15|00]È
[2570320] <[06|01|16|00|00]
[2573108] >[00|01|16|00]È
[2583108] <[06|01|17|00|00]
[2583200] >[00|01|17|00]È
[2593198] <[06|01|18|00|00]
[2594526] >[00|01|18|00]È
[2604526] <[06|01|19|00|00]
[2604625] >[00|01|19|00]È
[2614625] <[06|01|1A|00|00]
[2615255] >[00|01|1A|00]È
[2625255] <[06|01|1B|00|00]
[2625364] >[00|01|1B|00]È
[2635365] <[06|01|1C|00|00]
[2635458] >[00|01|1C|00]È
[2645459] <[06|01|1D|00|00]
[2646033] >[00|01|1D|00]È
[2656033] <[06|01|1E|00|00]
[2656154] >[00|01|1E|00]È
[2666155] <[06|01|1F|00|00]
[2671155] Cmd error
[2671156] Connecting to blynk-cloud.com:8442
[2685026] Connecting to blynk-cloud.com:8442
[2699150] Connecting to blynk-cloud.com:8442
[2713199] Connecting to blynk-cloud.com:8442
[2727323] Connecting to blynk-cloud.com:8442
[2741447] Connecting to blynk-cloud.com:8442
[2755597] Connecting to blynk-cloud.com:8442
[2769721] Connecting to blynk-cloud.com:8442
[2783845] Connecting to blynk-cloud.com:8442
[2797994] Connecting to blynk-cloud.com:8442
[2812068] Connecting to blynk-cloud.com:8442
[2826242] Connecting to blynk-cloud.com:8442
[2840341] Connecting to blynk-cloud.com:8442
[2854465] Connecting to blynk-cloud.com:8442
[2868639] Connecting to blynk-cloud.com:8442
[2882763] Connecting to blynk-cloud.com:8442
[2896862] Connecting to blynk-cloud.com:8442
[2910912] Connecting to blynk-cloud.com:8442
[2925061] Connecting to blynk-cloud.com:8442
[2939285] Connecting to blynk-cloud.com:8442
[2953359] Connecting to blynk-cloud.com:8442
[2967433] Connecting to blynk-cloud.com:8442
[2981532] Connecting to blynk-cloud.com:8442
[2995556] Connecting to blynk-cloud.com:8442
[3009680] Connecting to blynk-cloud.com:8442
[3023804] Connecting to blynk-cloud.com:8442
[3037879] Connecting to blynk-cloud.com:8442
[3051978] Connecting to blynk-cloud.com:8442
Is this something that I can fix or am I asking too much of the ESP8266, and should I instead use my Raspberry Pi as my Blynk host?
