[SOLVED] Menu input not working
menu input not working here’s the code…
http://pastebin.com/knGEdpQr
@SlaveDuino format the code, explain what is not working i.e. what result are you getting and what was you expecting.
i was expecting the servo to move and eject marbles @Costas
If you had studied the sketch extract I gave you earlier you would know what the problem is.
“9” not 9.
ISO C++ forbids comparison between pointer and integer [-fpermissive]
@costas
edit does not work 9 works not “9”
Lose this from loop()
  lcd.clear();
  lcd.print(0,0,"Thinking...");
  lcd.clear();
  lcd.print(0,0,riddleUP);
  lcd.print(0,1,riddleDOWN);
Use this:
if (String("9") == param.asStr()) {
still does not work even worse lcd display issue :sob:
Assuming your LCD is working try this:
BLYNK_WRITE(V1)
    lcd.print(0,0,"Look it works");
    myservo.write(0);
    myservo.write(180);
  else{
    lcd.print(0,0,"wrong");
not even riddle printing on lcd nothing happening :dizzy_face:
@Costas
http://pastebin.com/bD0NDQu3
I hope you have moved that nonsense from loop().
http://pastebin.com/jhEVMcc4
nothing hapenning still the same :confounded:
@Costas
magically started after 10 minutes :astonished::smile:
@costas
