I am working on a project and need to control the brightness of the 3 leds RGB via the slider widget and cant seem to figure out how to write the code. Can some one edit my code. It is working perfectly but not the the slider and when I use widget led I am getting an error login timeout.
This is the working code
Social networks: http://www.fb.com/blynkapp
http://twitter.com/blynk_app
This example runs directly on ESP8266 chip.
You need to install this for ESP8266 development:
Please be sure to select hte right ESP8266 module
in the Tools -> Board menu!
#define redpin 14
#define greenpin 12
#define bluepin 13
#define redvirt 5
#define grnvirt 6
#define bluevirt 7
#define witvirt 8
#define yellvirt 9
#define cyanvirt 10
#define vilvirt 14
char auth[] = "8374e7ea0b454xxxxxxxxxxxxxxxxx";
Blynk.begin(auth, "CxxxxxxxxWi-Fi", "xxxxxxxx");
pinMode(redpin, OUTPUT);
pinMode(bluepin, OUTPUT);
pinMode(greenpin, OUTPUT);
digitalWrite(redpin, LOW);
digitalWrite(greenpin, LOW);
digitalWrite(bluepin, LOW);
BLYNK_WRITE(V0) // At global scope (not inside of the function)
if ( param.asInt() == 1 )
digitalWrite(redpin, HIGH);
BLYNK_WRITE(V1) // At global scope (not inside of the function)
digitalWrite(greenpin, HIGH);
BLYNK_WRITE(V2) // At global scope (not inside of the function)
digitalWrite(bluepin, HIGH);
BLYNK_WRITE(3) // At global scope (not inside of the function)
analogWrite(redpin, param.asInt());
analogWrite(bluepin, param.asInt());
analogWrite(greenpin, param.asInt());
BLYNK_WRITE(V4) // At global scope (not inside of the function)
analogWrite(redpin, 1);
analogWrite(greenpin, 1);
analogWrite(bluepin, 1);
analogWrite(redpin, 0);
analogWrite(greenpin, 0);
analogWrite(bluepin, 0);
BLYNK_WRITE(V11) // At global scope (not inside of the function)
BLYNK_WRITE(V12) // At global scope (not inside of the function)
digitalWrite(bluepin, LOW); //off
And Dashboard
