[Solved] Loosing connection to blynk after 2-5 minutes
hi
now I finally have my Heatipump monitor ready and running.
Its an arduino uno with a w5100 shield and a protoshield and a attiny85.
Its primary job:
  1. send temperature logs for 4 ds18b20 sensors every 3 seconds.
  2. Detect when the heating is using power and report it to blynk (sends 3-4 times a minute)
    Using attiny85 to monitor a blinking led with a LDR sensor.
Problem
But now its has begun to loose connection to blynk server.
The connection last about 2-5 minutes, then I can see in the android app that its offline.
It still has lan network connection, I can ping it.
Anyone have a idea why this is happening or how to debug to narrow down the problem?
here’s my code:
#include <Ethernet.h>
#include <OneWire.h>
#define DEBUG
// #define ONE_WIRE_BUS 2        // This is the ESP8266 pin
// OneWire oneWire(ONE_WIRE_BUS);
// DallasTemperature sensors(&oneWire);
// DeviceAddress tempSensor1 = { 0x28, 0xFF, 0x35, 0x11, 0x01, 0x16, 0x04, 0x25 }; // Temperature probe #1
// DeviceAddress tempSensor2 = { 0x28, 0xC6, 0x89, 0x1E, 0x00, 0x00, 0x80, 0xAA }; // Temperature probe #2
// Digital pin the DS18B20 is connected to. Do not use digital pins 0 or 1 since those conflict with the use of Serial.
const int tmpPin1 = 7;
const int tmpPin2 = 6;
const int tmpPin3 = 5;
const int tmpPin4 = 3;
OneWire oneWire1(tmpPin1);
OneWire oneWire2(tmpPin2);
OneWire oneWire3(tmpPin3);
OneWire oneWire4(tmpPin4);
DallasTemperature sensors1(&oneWire1);
DallasTemperature sensors2(&oneWire2);
DallasTemperature sensors3(&oneWire3);
DallasTemperature sensors4(&oneWire4);
char auth[] = "";
// powermeter
long pulseCount = 0;
//Used to measure power.
unsigned long pulseTime, lastTime, elapsedTime;
//power and energy
double power, elapsedkWh;
//Number of pulses per wh - found or set on the meter.
int ppwh = 1; //1000 pulses/kwh = 1 pulse per wh
  Blynk.begin(auth);
  // KWH interrupt attached to gpio2
  attachInterrupt(digitalPinToInterrupt(2), onPulse, FALLING);
    // Wait until connected
  // These timers are used so that data does not flood Blynk
  timer.setInterval(3003L, sendSensor1);
  timer.setInterval(3006L, sendSensor2);
  timer.setInterval(3009L, sendSensor3);
  timer.setInterval(3012L, sendSensor4);
void sendSensor1() {
  sensors1.requestTemperatures();
  Blynk.virtualWrite(1, sensors1.getTempCByIndex(0) + 6.5);
void sendSensor2() {
  sensors2.requestTemperatures();
  Blynk.virtualWrite(2, sensors2.getTempCByIndex(0) + 6.5);
void sendSensor3() {
  sensors3.requestTemperatures();
  Blynk.virtualWrite(3, sensors3.getTempCByIndex(0) + 6.5);
void sendSensor4() {
  sensors4.requestTemperatures();
  Blynk.virtualWrite(10, sensors4.getTempCByIndex(0));
// The interrupt routine
void onPulse()
//used to measure time between pulses.
  lastTime = pulseTime;
  pulseTime = millis();
//pulseCounter
  pulseCount++;
//Calculate power
  power = (36000000 / (pulseTime - lastTime))*(ppwh*0.01);
  elapsedTime = (pulseTime - lastTime);
//Find kwh elapsed
  elapsedkWh = (1.0*pulseCount/(ppwh*100)); //multiply by 1000 to pulses per wh to kwh convert wh to kwh
//Print the values.
  Serial.print("Average Power pr kwh: ");
  Serial.print(power);
  //Serial.print("\npulseTime: ");
  //Serial.print(pulseTime);
  //Serial.print("\nlastTime: ");
  //Serial.print(lastTime);
  //Serial.print("\nelapsedTime: ");
  //Serial.print(elapsedTime);
  Serial.print("\nelapsedkwh: ");
  Serial.print(elapsedkWh);
  Serial.print("\nsending power result\n\n");
  Blynk.virtualWrite(4, power); // pin virtual
  Blynk.virtualWrite(5, elapsedkWh); // pin virtual
And the attiny85 code
  pinMode(0, OUTPUT); //pin 0 output
  int FotoR = analogRead(3); //input pin 3 to LDR sensor
    if (FotoR >= 100) // LDR sensibility
      digitalWrite(0, HIGH); //
     delay (100);
    digitalWrite(0, LOW); //
Added a fitzing drawing
Check if it’s one of the many faulty W5100’s at https://forum.arduino.cc/index.php?topic=372779.0
Not sure if its the W5100 shield, because It has run for quite a time.
Its after I have added the attiny85 and the power/LDR section.
If I comment out
so its not running the void onpulse function, it gets stable again.
When the interrupt is triggered disable the trigger, do your processing and then re-enable the interrupt.
You should really be using SimpleTimer not delay().
Think I got it solved.
Looked up Attachinterrupts and something about not using the direct pin but instead declare it.
like:
const byte interruptPin = 2;
attachInterrupt(digitalPinToInterrupt(interruptPin), onPulse, FALLING);
But that didnt solve it.
Then I looked back at the orriginal source
and remembered I removed one section:
void sendUptime, containing the blynk virtualwrite
because I couldnt see the point when I could send the blynk virtualwrite in the void onpulse.
But now I changed it
added
timer.setInterval(3016L, sendUptime);
void sendUptime()
and in void onPulse
remove the delays
and the blynkvirtualwrites thats now moved to the senduptime.
And it works…
The conclusion and lesson for me, dont have the Blynk.virtualWrite in a interrupt routine.
thanks for helping.
Will post my project later in a complete form.
