Hi all.
Today I update fron 0.23.1 to 0.23.2 server. When I start it I see a new next error message than in
0.23.1 version no. And the server work worst. The devices disconnect frequently.
Is there something I’m missing?
Regards,
Jaume Nogués
rPrim Tech School
2017 1:45:15 PM org.postgresql.Driver connect
SEVERE: Connection error:
org.postgresql.util.PSQLException: Connection to localhost:5432 refused. Check that the hostname and port are correct and that the postmaster is accepting TCP/IP connections.
at org.postgresql.core.v3.ConnectionFactoryImpl.openConnectionImpl(ConnectionFactoryImpl.java:265)
at org.postgresql.core.ConnectionFactory.openConnection(ConnectionFactory.java:49)
at org.postgresql.jdbc.PgConnection.<init>(PgConnection.java:194)
at org.postgresql.Driver.makeConnection(Driver.java:431)
at org.postgresql.Driver.connect(Driver.java:247)
at com.zaxxer.hikari.util.DriverDataSource.getConnection(DriverDataSource.java:95)
at com.zaxxer.hikari.util.DriverDataSource.getConnection(DriverDataSource.java:101)
at com.zaxxer.hikari.pool.PoolBase.newConnection(PoolBase.java:356)
at com.zaxxer.hikari.pool.PoolBase.newPoolEntry(PoolBase.java:199)
at com.zaxxer.hikari.pool.HikariPool.createPoolEntry(HikariPool.java:444)
at com.zaxxer.hikari.pool.HikariPool.checkFailFast(HikariPool.java:515)
at com.zaxxer.hikari.pool.HikariPool.<init>(HikariPool.java:112)
at com.zaxxer.hikari.HikariDataSource.<init>(HikariDataSource.java:72)
at cc.blynk.server.db.DBManager.<init>(DBManager.java:78)
at cc.blynk.server.db.DBManager.<init>(DBManager.java:51)
at cc.blynk.server.Holder.<init>(Holder.java:113)
at cc.blynk.server.launcher.ServerLauncher.start(ServerLauncher.java:71)
at cc.blynk.server.launcher.ServerLauncher.main(ServerLauncher.java:65)
Caused by: java.net.ConnectException: S’ha refusat la connexió
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350)
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206)
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
at java.net.Socket.connect(Socket.java:589)
at org.postgresql.core.PGStream.<init>(PGStream.java:62)
at org.postgresql.core.v3.ConnectionFactoryImpl.openConnectionImpl(ConnectionFactoryImpl.java:144)
... 17 more
Do you use DB on your local server? Where do you see this error? It is not related to “device offline”.
My server is a raspberry pi. I don’t use DB. The devices are online but suddenly the connections is lost. The connections is recovery but seconds or minutes later disconnect another time. With 0.23.1 server the system work rock solid!
Latest server hasn’t any changes regarding active connections handling. Most probably issue in your code.
Regarding exception - in what log do you see it? If in postgres.log
that is fine and you may ignore it.
I also had this issue when upgrading from 0.23.1. It looks like it was enabling raw data storage (I think that’s what it’s called). Either you can disable it or just install PostgresSQL, I did the latter and it’s working perfectly now.
Hi ThatGuy, I have in my server.properties this:
#enable raw data storage to DB
enable.raw.db.data.store=false
Is enough? or I must do something more?
regards
same error for me on windows 10 64bit… local server
Mar 25, 2017 6:01:56 PM org.postgresql.Driver connect
Caused by: java.net.ConnectException: Connection refused: connect
at java.net.DualStackPlainSocketImpl.waitForConnect(Native Method)
at java.net.DualStackPlainSocketImpl.socketConnect(Unknown Source)
at java.net.AbstractPlainSocketImpl.doConnect(Unknown Source)
at java.net.AbstractPlainSocketImpl.connectToAddress(Unknown Source)
at java.net.AbstractPlainSocketImpl.connect(Unknown Source)
at java.net.PlainSocketImpl.connect(Unknown Source)
at java.net.SocksSocketImpl.connect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
... 17 more
Blynk Server 0.23.2 successfully started.
All server output is stored in folder 'C:\My_Server\.\logs' file.
DB not in use
postgres.log
2017-03-25 18:01:55.083 - DB url : jdbc:postgresql://localhost:5432/blynk?tcpKeepAlive=true&socketTimeout=150
2017-03-25 18:01:55.083 - DB user : test
2017-03-25 18:01:55.085 - Connecting to DB...
2017-03-25 18:01:57.347 - Not able connect to DB. Skipping. Reason : Failed to initialize pool: Connection to localhost:5432 refused. Check that the hostname and port are correct and that the postmaster is accepting TCP/IP connections.
Please use latest server version. This issue is fixed there.
@Dmitriy
Blynk Server 0.23.3 successfully started.
work fine.
Server 0.23.3 works fine !!!
Good job!
