I’ve an Arduino WiFI shield (this one Arduino WiFi shield), on top of an Arduino Mega 2560… well… my sketch worked great until the 0.3.3 version.
With this latest library I’ve continuosly connection and disconnection.
I’ve turned back to 0.3.1 and all works fine.
You need some test by me?
Could you please try with a simplest example in the Blynk library, and send us your console output.
Thanks!
Okay… this is my code… (the example on the Blynk library).
#define BLYNK_PRINT Serial // Comment this out to disable prints and save space#include <SPI.h>#include <WiFi.h>#include <BlynkSimpleWifi.h>`
char auth[] = "dd75d9243bba45dab02a90ffbe58fc51";
// Your WiFi credentials
char ssid[] = "FRITZ!Box Fon WLAN 7390";
char pass[] = "4506523768287213"; // Set to "" for open networks
Blynk.begin(auth, ssid, pass, IPAddress(192,168,1,110), 8442);
// Or specify server using one of those commands:
//Blynk.begin(auth, ssid, pass, "server.org", 8442);
//Blynk.begin(auth, ssid, pass, server_ip, port);
This is the Serial Monitor output for the 0.3.1…
[398] Connecting to FRITZ!Box Fon WLAN 7390...
[10400] My IP: 192.168.1.152
[10401] Blynk v0.3.1
[10401] Connecting to 192.168.1.110:8442
… and this for the 0.3.3 …
[397] Connecting to FRITZ!Box Fon WLAN 7390...
[10401] My IP: 192.168.1.152
[10402] Blynk v0.3.3
[10403] Connecting to 192.168.1.110:8442
[14136] Ready (ping: 1066ms).
[19137] Connecting to 192.168.1.110:8442
[20756] Ready (ping: 1611ms).
[25757] Connecting to 192.168.1.110:8442
[27414] Ready (ping: 1652ms).
[32415] Connecting to 192.168.1.110:8442
[34080] Ready (ping: 1660ms).
[39081] Connecting to 192.168.1.110:8442
[40729] Ready (ping: 1642ms).
[45730] Connecting to 192.168.1.110:8442
[47389] Ready (ping: 1654ms).
[52390] Connecting to 192.168.1.110:8442
[54046] Ready (ping: 1650ms).
… and so on …
This is the Serial Monitor with BLYNK_DEBUG…
[10401] Blynk v0.3.3
[10402] Connecting to 192.168.1.110:8442
[10434] <msg 2,1,32
ÿdd75d9243bba45dab02a90ffbe58fc51
[12045] >msg 0,1,200
[12046] Ready (ping: 1557ms).
[12046] <msg 17,1,97
ÿver0.3.3h-beat10buff-in256devArduinocpuATmega2560conHDG204buildMar 5 2016 18:42:00
[12175] Sent 5/102
[17047] Connecting to 192.168.1.110:8442
[17051] <msg 2,1,32
[18719] >msg 0,1,200
[18719] Ready (ping: 1637ms).
[18720] <msg 17,2,97
[18849] Sent 5/102
[23720] Connecting to 192.168.1.110:8442
[23725] <msg 2,1,32
This is the Serial Monitor with BLYNK_DEBUG with the old library 0.3.1
[10399] My IP: 192.168.1.152
[10400] Blynk v0.3.1
[16138] <msg 2,1,32
[18214] >msg 0,1,200
[18214] Ready (ping: 2074ms).
[18219] >msg 20,1,17
>pm0in0in0in
[26141] <msg 6,1,0
[26381] >msg 0,1,200
[36143] <msg 6,2,0
[36686] >msg 0,2,200
Thank you very much.
The problem is, that Blynk tries to send more info upon connection.
You can put #define BLYNK_NO_INFO on the top of the sketch as a temporary workaround.
We will try to fix this in next release.
Ok… all works fine with your simple workaround!
Great work!
