[Solved] Irrigation System Relay Control
Hi All, I am creating a Blynk based irrigation system using a Wiolink with the following sensors:
  • Valve Control Output Relay
  • 1 ADC Soil Humidity Sensor
  • 2 I2C ADS1015 connected Soil Humidity Sensors
  • BMP085 Pressure Sensor
  • Basic DHT Humidity/Temperature Sensor
  • TSL2561 Light (UV) Sensor
  • Battery Voltage Sensing (Via ADS1015)
All the code works (although a bit messy - im new to this so lots of copy paste) except I currently am using direct control of the relay on pin13 via GP13 in the App. However when switched on in the app, the relay goes on then randomly switches off (uncommanded) - likely due to the time it takes to execute the code somehow, is there a way of preventing this? Should connect the relay switch in the app to a virtual pin then code the relay to switch instead, any ideas of some code to do this? Thanks all, just a bit stuck at the moment
Irrigation System Controller
Based on WioLink Board with:
- Valve Control Output Relay
- 1 ADC Soil Humidity Sensor
- 2 I2C ADS1015 connected Soil Humidity Sensors
- BMP085 Pressure Sensor
- Basic DHT Humidity/Temperature Sensor
- TSL2561 Light (UV) Sensor
- Battery Voltage Sensing (Via ADS1015)
#include <DHT.h>
#include <Wire.h>
#include <wiring_private.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BMP085_U.h>
#include <Digital_Light_TSL2561.h>
#include <Adafruit_ADS1015.h>
char auth[] = "048ea82e09c24f768c80a047d2888326";
char ssid[] = "SKY36D33";
char pass[] = "FPFXCAYC";
// Hardware Settings //
#define LED_PIN    5
#define RELAY_PIN 13
#define DHTPIN 12
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
Adafruit_BMP085_Unified bmp = Adafruit_BMP085_Unified(10085);
Adafruit_ADS1015 ads1015;    // Construct an ads1015 at the default address: 0x48
int analogPin = 0;
int moi0;
 Wire.begin();
 TSL2561.init();
 ads1015.begin();
 ads1015.setGain(GAIN_TWOTHIRDS);     // 1x gain   +/- 4.096V  1 bit = 2mV
//Setup for Grove Modules
pinMode(15, OUTPUT);
digitalWrite(15, 1);
//INIT HARDWARE
  pinMode(LED_PIN, OUTPUT); // LED output
  pinMode(RELAY_PIN, OUTPUT); // RELAY
//Init Blynk
    dht.begin();
  /* Initialise the sensor */
  if(!bmp.begin())
    /* There was a problem detecting the BMP085 ... check your connections */
    Serial.print("Ooops, no BMP085 detected ... Check your wiring or I2C ADDR!");
    while(1);
void sendSensor()
  float h = dht.readHumidity();
  sensors_event_t event;
  bmp.getEvent(&event);
  float p = event.pressure;
  float lx = TSL2561.readVisibleLux();
 int16_t moi1 = ads1015.readADC_SingleEnded(0);
int16_t moi2 = ads1015.readADC_SingleEnded(1);
int16_t moi3 = ads1015.readADC_SingleEnded(2);
int16_t vcx = ads1015.readADC_SingleEnded(3);
moi0 = analogRead(analogPin);
float vcxcal;
float vxres;
float px;
vcxcal = (float)vcx/168.0;  //Calculate Voltage
vxres = round(vcxcal*100)/100.0; //Round Voltage
px = (float)p + 10.6; //Calculate Pressure
px = round(px*10)/10.0; //Round Pressure
moi0= (float)moi0/8.61;
moi2= (float)moi2/11.9;
moi3= (float)moi3/11.9;
  if (isnan(h) || isnan(t)) {
    return;
  Blynk.virtualWrite(V5, h);
  Blynk.virtualWrite(V6, t);
  Blynk.virtualWrite(V7, px);
  Blynk.virtualWrite(V8, lx);
  Blynk.virtualWrite(V9, moi1);
  Blynk.virtualWrite(V10, moi2);
  Blynk.virtualWrite(V11, moi3);
  Blynk.virtualWrite(V12, vxres); //Voltage Value Output
  Blynk.virtualWrite(V13, moi0);
  Blynk.virtualWrite(V14, vcx); //Voltage Calibration
BLYNK_WRITE(vPin) {  // Button Widget
  int RelaySwitch = param.asInt();
  if (RelaySwitch == 1) {
    digitalWrite(RELAY_PIN, 1);
    digitalWrite(RELAY_PIN, 0);
Thanks for the code, however it comes back with:
a function-definition is not allowed here before ‘{’ token
I have tried moving the brackets but then it throws a:
expected initializer before ‘int’
Any ideas? Many Thanks
All Solved, Many Thanks
Or simplified…
    digitalWrite(RELAY_PIN, param.asInt());
